plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 9th, 2012, 03:57 PM   #1
joigunni
Supporting Member
Iceland
joigunni is offline
Citect/cicode
Hi
I have a Local Variables in Citect set with “zero scale=0” and “full scale =12” now I want to change the full scale at Runtime, can I do that in Cicode?
Old January 10th, 2012, 03:44 PM   #2
jimtech67
United States
jimtech67 is offline
jimtech67's Avatar
This is a bump
I would love to know if this is possible.
Old January 10th, 2012, 08:03 PM   #3
PeterW
Canada
PeterW is offline
Are these tags in the tag base? real IO or memory.
CICODE cannot access tags but you can pass and return parameters.
eg
CICODE
INT
FUNCTION
TEST(INT A)
INT X = A;
RETURN X
END
from the graphic page have an instruction, inside a button perahps
FullScale = TEST(NewValue)
Is this what you mean?
edit. Not sure I've answered right, thinking now you may have a string tag with the contents "Full Scale =12", if so then the above maybe still valid as a pointer, instead of INT at the beginning use STRING and the entry argument could be changed to STRING etc.
Old January 10th, 2012, 08:24 PM   #4
Dua Anjing
Australia
Dua Anjing is offline
Dua Anjing's Avatar
In earlier versions it was actually possible (but not simple,easy or recommended). There were a set of undocumented functions relating to RDB's. RDB's are (or were) the runtime data base files that Citect used when you compiled youre project. One problem with doing them would be that next time you compile dyou would overwrite the RDB with data from the off-line file (variable.dbf) But that wa sin earlier versions (V3 & V4) I havn't used any of these in later version sand don't even know if they still exist.
__________________
Now that food has replaced s*x in my life I can't even get into my own pants
Old January 11th, 2012, 03:28 PM   #5
joigunni
Supporting Member
Iceland
joigunni is offline
ok, but thanks for your help, have to find some other way.
Old January 26th, 2012, 07:40 AM   #6
tragically1969
United Kingdom
tragically1969 is offline
Quote:
As people took the time to answer you and give advice it would be considered courteous to share how you did it if you did find a solution.......
Old January 29th, 2012, 02:48 AM   #7
joigunni
Supporting Member
Iceland
joigunni is offline
I did not find a actual solution. In my program I have a weight scale mad by rectangle that will fill up by red color when it sense some weight. The scale is from 0 to 500 kg. In some case I want to be able to change to higher scale, like from 0 to 2000 kg. At first I put the scale setting in the “Variables Tags” to “Eng Zero Scale = 0” and “Eng Full Scale=500” but as you know there is no way to change those scale in run-time so I cleared those settings and instead made small mat-formula.
Calculated_weight= ((input_weight*3)*2000)/scale_value
// Analog input from PLC give me scale that is 0-10500,
//variable-tag scale is 0-32000
//Max weight is 2000kg
//on Max weight 2000kg I will get 10500 from PLC analog-input
if I put the scale_value to 500kg, the math will look like this:
Calculated_weight= ((10500*3)*2000)/500
Calculated_weight=126000
And if I got 500kg on PLC input, PLC will give me 2625, and the math will look like this:
Calculated_weight= ((2625*3)*2000)/500
Calculated_weight=31500
And the rectangle will be filed
If I still have 500kg on PLC input, and put the scale_valu to 1000kg, the math will look like this:
Calculated_weight= ((2625*3)*2000)/1000
Calculated_weight=15750
And the rectangle will be half filed
Old January 29th, 2012, 02:32 PM   #8
PeterW
Canada
PeterW is offline
I don't know, I'm currently passing data between citect tags, variable tags and IO tags with citect, using the method I said above. (It appears my reply was ignored though)
Maybe its an 'English not first language' problem. But I still don't know the format of the tags you were trying to change, the way you put the lot in a string made it look like the tags were string tags, but your talking about numbers which means integer.
Confusing.
Old January 29th, 2012, 06:08 PM   #9
joigunni
Supporting Member
Iceland
joigunni is offline
You are probable right, ‘English not first language’ problem. I’m using integer Tags.
See this picture, I’m trying to change this parameters “zero scale=0” and “full scale =100”, I mean I want to change this parameters in Runtime.
Old January 29th, 2012, 06:28 PM   #10
jimtech67
United States
jimtech67's Avatar
I got his from Citect Support when I inquired.
Hello Jim,
It is not possible to change the scaling when the application is running and get the changed scale to be implemented online. There is no cicode function or mechanism to achieve the requirement in v6.10. It is because potentially it could cause an mismatch of historical trend data and thus, hindering the system to run (if you are trending the variable tag).
In v7.xx onwards, you can do online changes by restarting the necessary processes after you made the changes (running multi-process). Other than that, there is no mechanism to change the scale of the tag on-the-fly.
Please advise me if you have further inquiry.
Best Regards,
Dennis
Old January 30th, 2012, 03:41 PM   #11
chelton
Australia
chelton is offline
Why not create a "scale" tag that can be changed at runtime, then from your rectangle "fill properties" call a cicode function to create the scale you want.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
