automat_plc
i am new in Beckhoff products(PLC) and MODBUS so please help ...
i have Beckhoff PLC BX8000-0000 with KL6041-RS422(485),24Byte serial inetrface.
This serial interface is connected with Modbus device NOVUS N2000(slave address=2, MODBUS RTU 485 ) by terminals:
KL6041: N2000:
TxD+ to D1(between D1 and D0 = 120ohms tremination resistor)
TxD- to D0
GND to GND
In attachment You can find my source code(TwinCat), i want to read first 10 registers from slave device to Beckhoff PLC.
I don't have software KS2000 for interface configuration, so i configured serial interface in source code by function block KL6configuration and i also used
function block ModbusRtuMaster_KL6x22B.ReadRegs for reading registers from slave.
But in function block KL6configuration i allways get error : COMERROR_TIMEOUT .
In function block ModbusRtuMaster_KL6x22B.ReadRegs i have no error !!
Please help: how to configure KL6041 serial interface to works like RS485 and also works without errors
Thank You very much,
Best regrds!!
P.S. please note:
Modbus device NOVUS N2000 ... all parametrs are O.K., and works fine with other device on the same parameters!!
KL6041: N2000:
TxD- to D0
GND to GND
Best regrds!!
P.S. please note:
