s7 300 343-1 advan help
Tommycai
Aug 2011
KY
120
I have a 313-6CF03-0AB0 V 2.6.9 Connected to a 343-1GX30-0XEO V 1.2
First question Are they compatible? I looked it up on Siemens Website and the CPU is not listed?
http://support.automation.siemens.c...objaction=csview&extranet=standard&viewreg=WW
Second question I'm not really understanding the FC5 and FC6 in the manual page # 193
http://support.automation.siemens.c...slib.csinfo&lang=en&objid=8777865&caller=view
do I just make the same stl then call fc5 or fc50? am I understanding that correctly?
I have an S7-300 and an HMI. The HMI is the only device that talks over Profinet through the CP343-1 module. It's run fine for a couple of years...
481
I can not see the CPU s7-300 i only see the cp343 as photo the interface is through tcp/ip how can I upload the station via the cp343 module ???
973
Good morning, a client has requested me a communication between 4 Siemens S7-300 PLCs and a BACnet Network, and there is very little...
1,962
Dear All I have worked with MODBUS TCP and RTU many times and commissioned successfully. Here First time I m working with S7300 to establish...
3,150
Hello all in this forum, as you can see I'm new here this is my first post. So here it goes: I want to know if someone has done this before...
1,842
