This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Siemens Analog Inputs
Hello Folks, I am trying to figure out how to make use of analog inputs and outputs in Siemens S7. I am familiar with Allen Bradley and for them I would just add a rung using a SCP scale with parameters which would look at the analog value comming in, scale it and send it to a location in my PLC. Very simple, is there a similar method in Step7. Your help would be greatly appreciated.
#2 |
Look under your program elements> Libraries>Standard Library>
TI-S7 Converting Blocks>FC105 and FC107. If you click on these and press F1- a help menu will appear. These will do what you are looking for, or build your own with a function or function block. |
#3 |
FC105
I know there are other ways but FC105 is faily similar to the SCP in AB. Load the FC and the call it from you OB and it should work just fine.
#4 |
Gentlemen, I appreciate the hell out of this information. I will be sure to give it a try!
#5 |
I put a scaling function in the file area under Siemens a while ago.
#6 |
HERE is a previous thread about exactly the same topic.
In that thread I posted some S7 code that works exactly as the AB SCP function. FC105 is a bit different from SCP (but is OK of course).
__________________
Jesper
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Siemens CPU313C Analog Inputs | sherman4 | LIVE PLC Questions And Answers | 2 | February 25th, 2005 03:02 AM |
| S7 300 SM331 Analog Inputs Problem; Relative DC leval of adjacent inputs. | David Torrens | LIVE PLC Questions And Answers | 4 | November 10th, 2004 10:14 AM |
| Analog Inputs | asha6965 | LIVE PLC Questions And Answers | 4 | August 17th, 2004 03:32 PM |
| siemens analog inputs | GTX | LIVE PLC Questions And Answers | 12 | March 13th, 2004 10:50 PM |
| Siemens Analog Inputs Shared | Kthiel | LIVE PLC Questions And Answers | 0 | July 3rd, 2002 01:29 AM |
