plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 1st, 2012, 09:04 AM   #1
ddwilson1
United States
ddwilson1 is offline
Magelis XBTGC2230 issue
Is there a way to reset the unit to factory defaults?
The problem is the first time I programmed it for testing I set up download protection but forgot to set up the log in and password now it will not allow downloads or changes without the user name and password. This is a brand new unit so do not think
scrapping it is a possibility even though a large hammer has been considered.
Doug
Old March 1st, 2012, 07:36 PM   #2
robertkjonesjr
United States
robertkjonesjr is offline
Try to use a USB disk. Compile and tell VD to write files to usb, plug disk into unit, and away you go (hopefully). Assumes your device supports a USB disk... mine did when I had this issue a few weeks back. Won't reset to factory defaults, but you can put a minimal application on the device.
Should have checked first - this looks like a SoMachine-based controller, not Vijeo Designer. Not sure if the Vijeo Designer solution above works this way for this device or not.
Old March 1st, 2012, 07:47 PM   #3
robertkjonesjr
United States
There's hope - I could change from SoMachine to USB for download. Don't know if it will work, but this is what I would try.
Old March 2nd, 2012, 02:22 PM   #4
Engineer_MG
United States
Engineer_MG is offline
Engineer_MG's Avatar
I am Mohua, an application engineer with Schneider Electric.
Try the following
1. Start menu -> Schneider Electric -> VijeoDesigner -> Tools -> Runtime Installer -> XBTGC
OR
2. Empty project download via USB
If not you might have to send the unit back to reset back to factory mode, since , you have enabled "download security".
Do you have a local Schneider sales rep that you are working with ? They could assist with sending the unit back for resetting .
The XBTGC is a PLC+HMI combo unit that works with SoMachine which has the Vijeodesigner embedded for programming the HMI part. So , essentially one software .
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1769-ASCII buffer issue swayne76 LIVE PLC Questions And Answers 5 February 28th, 2012 09:58 PM
SLC 5/02 Issue cskaggs2 LIVE PLC Questions And Answers 11 January 11th, 2012 08:37 PM
Strange Speed Issue with FTV SE arkansascontrols LIVE PLC Questions And Answers 10 August 22nd, 2011 07:00 AM
Compact logix and panel view plus 600 compatibility issue ALT LIVE PLC Questions And Answers 18 December 25th, 2010 05:36 AM
AB 1734-AENT POint IO issue ettikudiappan LIVE PLC Questions And Answers 0 July 17th, 2007 09:42 PM
