This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Jun 2011
Automation Direct function
I am using Koyo DL06 PLC
Automation direct 5.3 try to calculate 2 ^ 1.55 ( 2 to the power of 1.55 ) I use this in the flow rate calculation, however, AD do not have the power function, all they have is square root function. Folks, any work around or tricks. Thanks. |
#2 |
2^1.55 = 2.9281713918912508413872626586825
It would be a constant, why calculate it?
__________________
Controlling outputs is the PLC's way of getting its inputs to change. www.thePLCguy.com |
#3 |
A quick web search of how to solve decimal exponents should point you in the correct direction for simplification of this problem.
A hint to get you started is to think of this as two exponents to solve, i.e. 2^1 x 2^0.55. When solving the decimal portion you'll need to convert it to a fraction in lowest terms and use the laws of exponents to finish it off. Don't want to do it all for you. ;-) I see Bernie is faster with a better solution.
__________________
Andrew Simione Design/Manufacturing Engineer Ron-Vik, Inc. |
#4 |
Sorry about the confusion, 2 is just an example. It is actually a variable. I am actually have problem with the 2^0.55 portion. 0.5 is fine, I can use the square root function, but 0.55 .....
#5 |
So you mean x^1.55 - then you'll need to follow ajsimione's advice.
__________________
#6 |
Thanks for the hints, but I am still stuck.
X ^ 0.55 = X ^ 11/20 = ( 20√ X) ^ 11 So sad, DL06 does not have 20√ function and the power function :.( |
#7 |
(20√ x) ^ 11 =
(20 * √ x) * (20 * √ x) * (20 * √ x) * (20 * √ x) * (20 * √ x) * (20 * √ x) * (20 * √ x) * (20 * √ x) * (20 * √ x) * (20 * √ x) * (20 * √ x) |
#8 |
lancie - your rewriting of (20√ x) as (20 * √ x) makes it look like your are changing the '20th root of x' into '20 times the square root of x'. That makes it confusing. Computing the 20th root of x would still be difficult.
__________________
#9 |
Thanks Lancie, yes I can multiple 11 times instead, but Bernie is correct. I cannot solve the 20th root of X. No such function in DL06 :-(
#10 |
Supporting Member
![]() Join Date: Nov 2006
What is your min/max range for x ?
Is a look up table a possibility ? |
#11 |
My old 5th grade math teacher taught me that (20√x) = 20 times √x.
Now the 20th root of X = X^1/20 = x^0.05 I suppose it was just sloppy symbol writing. |
#12 |
Thanks for the attempt, but I am still stuck on x^0.05.
Actually I am using the flow measurement well method for calculating the flow rate, look up table is not an option. For DL06, they only have add, subtract, multiple, divide, sin, cos, tan and sqrt function. :-( |
#13 |
Brian,
If you are really desperate, you possibly could convert your values to binary values, then use binary shifts (which the DL-06 does have) to perform the power terms. Please don't ask me to convert them for you - I have CRS and am just not able to concentrate enough to do that anymore! Possible instructions that could be used for binary power operations: ROTL ROTR SHFL SHFR INV Last edited by Lancie1; March 5th, 2012 at 07:18 PM. |
#14 |
Thanks Lancie, I will try it. Appreciate for your help! :-)
#15 |
Supporting Member
Repetitive use of the square root will allow to to compute the following terms which you can select to the accuracy you require.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Legal Drama involving Automation Direct and AVG Automation | danw | LIVE PLC Questions And Answers | 17 | February 7th, 2011 12:23 PM |
| Top 10 Reasons Why I Hate Programming Automation Direct Controllers | agarb | LIVE PLC Questions And Answers | 22 | December 3rd, 2009 08:34 PM |
| Automation Direct & GE Fanuc VersaMax Micro: 24VAC On 24VDC Inputs? | kittydog42 | LIVE PLC Questions And Answers | 7 | May 1st, 2009 05:31 PM |
| Automation Direct Modbus TCP | JACMAN | LIVE PLC Questions And Answers | 6 | April 17th, 2009 10:36 AM |
| temp control on automation direct | stu | LIVE PLC Questions And Answers | 1 | August 19th, 2008 12:32 PM |
