I have been trying to install RSLogix Emulate 500 for some schoolwork I have, each time it seems like it installs correctly, but whenever I try and run it I get this before it opens...
I have researched as much as I can on my own and it seems like it's a Registry Permissions issue. And the only troubleshooting info I can find from Rockwell is a PDF for RSLogix Emulate 5000 which says I need to remove a few keys in the registry. Unfortunately there is only one address listed that even comes close to what I have in my registry. I proceeded to allow all permissions for that, but that didn't change anything. I then deleted it from the registry and that screwed everything up so I removed everything and reinstalled RSL Emulate 500.
Does anybody know what I am doing wrong?
I am using Win7 64bit
Thank You!
Rob
Thank You!
Rob
