This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Dec 2007
S7MPI to Network
Hello,
I want connection MPI ports of S7300 to the kepware opc server. How can I do it? Which I should use converters? I connected with CP343-1 Lean card. But it is very expensive. Do you know another way? Best Regards |
#2 |
![]() Join Date: Oct 2008
Try to contact these companies with your configuration:
http://www.traeger.de/ http://www.process-informatik.de/produkte/s7-lan http://www.deltalogic.de/content/view/12/26/lang,en/ http://www.helmholz.de/ext/blaetterk...ndex.html#/72/ http://de.hilscher.com/products_deta...a9d72ac0e&bs=5 http://www.ibhsoftec-sps.de/english/...ardware_S7.htm http://www.inat.de/index.php?id=276&L=1 Kalle |
#3 |
The Kepware S7 TCP driver supports the use of the NetLink-50-MPI from Hilscher which allows you to use a single adapter to connect to multiple devices on the MPI network. You could also use a Serial to Ethernet converter with the S7MPI driver using Ethernet Encapsulation Mode.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| converting hex to decimal | steve500 | LIVE PLC Questions And Answers | 11 | September 5th, 2009 07:26 AM |
| PLC Network on Office Network??? | d21x | LIVE PLC Questions And Answers | 16 | September 19th, 2008 03:11 PM |
| timer trigger in s7300 | mostafah | LIVE PLC Questions And Answers | 26 | July 25th, 2008 01:11 AM |
| s7 200 | gaannesh | LIVE PLC Questions And Answers | 10 | April 20th, 2008 11:33 PM |
