plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 20th, 2012, 02:07 AM   #1
peelseeds
Canada
peelseeds is offline
Fancy Exclamation Great in the school world. new to the real world.
Hey everyone, I think i'm in a little over my head. school made me very confident with the familiarity of Rockwells software; RSLogix5000, FactoryTalk view studio, RSLinx, and some of the tools each of these application comes with. come the real world, I'm losing my confidence.
one of the main things I need to learn is how to download to the actual HMI's. I've never done this before, I have a strong IT background, great at operating computers, understand technical terminologies; I've done some searches here to find some insight, and I've read some things about using panelbuild32, using memory cards to transfer etc. not sure what method to use.
since the HMI application is created in FactoryTalk view studios, I messed around with that (offline of course and with a copy of the original application. I have a list/link of all the panels IP addresses (the shortcuts point to a FTP server where an existing .MER file exists for each panel). we are using DeviceNet.
NOTE: within FactoryTalk I've made sure all necessary users have been added, runtime security is setup properly for my users, my communication setup right now, points to the PLC so I can use my laptop as a 2nd hmi.
Assumption #1, create a runtime application --> .MER file. use the transfer utility --> select the created .MER file as the SOURCE file, select option parameters (run application at startup, and Replace communications) then in the destination terminal window --> select the HMI's IP I want to download to.
this is my assumption #2, create a runtime application and export/save to a .MER file --> since I have a list/link of all the panels IP addresses (the shortcuts point to a FTP server where an existing .MER file exists for each panel). Do I just copy or replace the existing .MER file on the FTP server?
I hope I'm not missing any critical information.
any pointers would be greatly appreciated and of course a precise answer to my question if possible.
also some pointers about configuring DeviceNet with RSNetworx would be a good idea to learn, just in case I need to add nodes. (is the RSnetworx tutorial.bat a good place to start?)
Thank you to anyone who's attempted to read this and provide their input. it is greatly appreciated.
take care,
-peelseeds .
Last edited by peelseeds; March 20th, 2012 at 02:13 AM. Reason: rephrasing, its been a long day
Old March 20th, 2012, 02:53 AM   #2
Saffa
New Zealand
Saffa is offline
Hi PeelSeeds,
From the info you've given, Assumption #1 is the way to go. I myself only have just recently started using FT View and that's pretty much the process I've just used a couple weeks back to set up a replacement Panelview 1000+ (They don't seem to like swimming much...).
I think your FTP server is probably a "storage area" for the runtime files, just incase anyone needs to restore a runtime file to an existing or replacement panel. Hopefully someone else knows, if it is a repository for the runtime files then it will probably need updating if you update a panel.
Cheers,
Steve
Old March 20th, 2012, 07:21 AM   #3
peelseeds
Canada
Saffa,
Thank you very much for your response.
can anyone else suggest ways I can understand and learn DeviceNet thoroughly in the shortest amount of time?
Thanks,
-peelseeds .
Old March 20th, 2012, 10:06 AM   #4
widelto
Colombia
widelto is offline
widelto's Avatar
Peelseeds: try downloading "the devicenet bible"
__________________
My two cents.
Old March 20th, 2012, 11:05 AM   #5
peelseeds
Canada
widelto, found it, thank you very much
is there anything similar to this in regards to GuardLogix controllers?
Last edited by peelseeds; March 20th, 2012 at 11:14 AM. Reason: last minute question
Old March 20th, 2012, 11:31 AM   #6
Helliana
United States
Helliana is offline
I've always uploaded my .MER files to my panelviews in one of two ways.
1) You can put the file on a USB flash drive, then copy the file from the USB flash drive to the Panelview file system. Just note that the .mer files have to be in an certain folder structure, don't remember the exact details.
2) In FactoryTalk Studio, go to Tools -> ME Transfer Utility. Using the program, you can find a path to the Panelview in RSlinx and upload directly to the filesystem.
Also, learning how to use DeviceNet and RSNetworks may be a good thing. I know we had a machine where i used to work that used DeviceNet and it gave the regular maintenance guys fits. They would just grab a photoeye or proc sensor out of the store room and change it out to try to troubleshoot a problem. Well before long, all the spares in the storeroom had random node addresses and caused more problems than it answered. You would then have to go reset all the nodes back to the correct address, and then find out what the problem with the machine was.
Old March 20th, 2012, 12:40 PM   #7
Doylen
United States
Doylen is offline
Doylen's Avatar
All good except "replacing communication" part. Do you really want to do that? That means, whatever you programmed via offline setup can be overwritten to online enterprise file. I won't mess with that if I was you. Welcome to PLC & FT world. You'll love it.
__________________
Doylen from Virginia
Does your supervisor knows you're helping others not your company?
Old March 20th, 2012, 08:17 PM   #8
peelseeds
Canada
Doylen, I don't think I fully understand what you're trying to say. could you provide an example when someone might want to use that parameter? I think I understand why someone might not want to use it, but some clarification would help greatly.
Old March 21st, 2012, 06:28 PM   #9
brendan.buchan
Australia
brendan.buchan is offline
Quote:
What he is saying is that it is not necessary to tick the "Replace communications" box unless you have made some changes to the RSLinx Enterprise communications setup in FT View Studio and specifically want to replace/update the communications settings on the HMI.
If you are just doing some minor changes to a screen then the majority of the time it is not necessary to replace the comm's settings.
An example of when you would want to replace the comm's settings is if you are adding in a new PLC that the HMI has to talk to.
Old March 22nd, 2012, 08:31 AM   #10
peelseeds
Canada
brendan.buchan, Got it. Thanks
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Micrologix 1400 - Rockwell's first real contender in the brick world. TConnolly LIVE PLC Questions And Answers 30 May 18th, 2009 01:45 PM
Example of a real world PID controller Pandiani LIVE PLC Questions And Answers 8 August 21st, 2008 11:23 AM
Using Computer to Control Real World riyajahamad LIVE PLC Questions And Answers 6 July 17th, 2004 03:08 AM
Experience with PLC jayshah11 LIVE PLC Questions And Answers 14 February 27th, 2003 10:07 AM
Real World Problem Vietnam Bob LIVE PLC Questions And Answers 8 November 23rd, 2002 03:03 PM
