plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 20th, 2012, 11:02 PM   #16
MechatronicsMan
Australia
MechatronicsMan is offline
A closer view of the TOWDATA
Old March 20th, 2012, 11:09 PM   #17
MechatronicsMan
Australia
Closer look at the Function Block option, so hopefully with Ken's solution and Mine you'll have all the info you need, let me know if you'd like me to send the CCW file
Old March 20th, 2012, 11:20 PM   #18
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Automation high-five !
Old March 20th, 2012, 11:25 PM   #19
MechatronicsMan
Australia
Automation Group Hug!!
Old March 21st, 2012, 12:18 AM   #20
(8{)} ( .)
Israel
(8{)} ( .) is offline
(8{)} ( .)'s Avatar
This software looks suspiciously like CoDeSys v3. Am I mistaken?
(8{)} (: .)
(Yosi)
Old March 21st, 2012, 01:05 AM   #21
MechatronicsMan
Australia
Hi Yosi
Not sure, I've never used Codesys
Old March 21st, 2012, 09:56 AM   #22
Ken Roach
United States
Ken Roach's Avatar
The Allen-Bradley Micro 800 series editor is built into a package called "Connected Components Workbench", or "CCW" that also launches configuration programs for the PanelView Component and the small Kinetix drives.
Under the hood, the controller is running ISaGRAF and PLCOpen Motion routines, and the editor is done in Microsoft Visual Studio.
The good news about CCW is that there's plenty of room for future improvement.
Old March 22nd, 2012, 08:49 PM   #23
ceilingwalker
United States
ceilingwalker is offline
ceilingwalker's Avatar
Quote:
Originally Posted by Ken Roach View Post
The hardest thing about this is learning how the TOW instruction doesn't have named instances, and uses instruction-specific time value structures named TOWDATA.
As you've stated the application, you can do this in three rungs:
Thank you. Mine looks the same except I had to add an "R_Trig" as sort of a one-shot for my push button. I'm just enjoying the fact that mine was the same as yours Ken. You being a seasoned veteran and all. Always appreciate yours and everyone heres' help. Thanks again.
Old March 22nd, 2012, 08:51 PM   #24
ceilingwalker
United States
Quote:
Originally Posted by MechatronicsMan View Post
Hi Ceiling walker
I've attached a picture of what I Meant earlier.
once you have the TOW block in the middle of your screen grab the Variable block from the left and drag it on to your screen as well. Then double click on the variable block you just dragged and it will take you to the variables that have been created already, if there aren't any you can create them as you go. Create TimeA and TimeB. they need to be data type TOWDATA. then fill in the details. I've attached a picture of the variables and the blocks the way you described your process
Thanks much. I always learn more here than at the manufacturer's site.
Old March 22nd, 2012, 08:58 PM   #25
ceilingwalker
United States
I do have a wiring question, please. I wanted 24VDC out to my push buttons so I have the "-" of the power supply connected to the "NC" terminal position and the "+" to the "I-00" terminal position. They are each connected to one side of the push button. I was expecting to see the input make and break, but nothing. Looking at the wiring diagram it appears that I have it wired correctly but nothing. Thank you
Old March 22nd, 2012, 09:23 PM   #26
jrwb4gbm
United States
jrwb4gbm is offline
"NC" on terminal strips usually mean "Not connected". Post the model plc and I will look at the terminations in the manual.
Page 10 in this manual in the link below, show some different layouts.
The only layout I see with the "NC" terminal is for the is for the 2080-LC10-12AWA. That model uses 120 to 240 VAC for the inputs, not 24VDC. Depending on the model, you may also have to jumper terminals 2 to 3 on the input strip if they are not already jumpered internally.
Link:
http://literature.rockwellautomation...n006_-en-p.pdf
Old March 22nd, 2012, 09:39 PM   #27
ceilingwalker
United States
Quote:
Page 10 in this manual:
Shows some different layouts.
Hopefully my attachment makes it here. This is what I was using.
Old March 22nd, 2012, 09:43 PM   #28
ceilingwalker
United States
Forgot to zip it. Here is the diagram I was using. Thanks again.
Old March 22nd, 2012, 10:14 PM   #29
jrwb4gbm
United States
jrwb4gbm is offline
Looking at the attached zip file that typical drawing appears to show a Com terminal that must be connected to the "0" or - side of the power supply. Then, one side of your pushbutton contact connects to the + 24v side of the input power supply thru a fuse. Next, the other side of the pushbutton contact connects to the Input or I/P.
I'm looking back thru the thread and I see you are using the 2080-LC10-12AWA. I think this might be the manual you are using. See the terminals layouts starting on page 21.
Link:
http://literature.rockwellautomation...m001_-en-e.pdf
P.S.
Go back and re-read my post #26. I made some edits.
Old March 23rd, 2012, 04:20 PM   #30
ceilingwalker
United States
Turns-out the module I purchased I can not use 24VDC, only 120VAC. The literature was a little confusing because I did not read anywhere that my model wouldn't support that voltage input.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Allen Bradley ControlLogix 5561 and IDEC HG3F via Ethernet/IP error ml90 LIVE PLC Questions And Answers 4 June 3rd, 2010 01:47 AM
allen bradley Rightsight 42EF-P2SCB-G4 Juan Stephens LIVE PLC Questions And Answers 0 March 8th, 2010 09:40 PM
Learning Allen Bradley mbferrari LIVE PLC Questions And Answers 9 March 11th, 2009 11:25 AM
Can't connect Allen Bradley to Telemecanique Madahbee LIVE PLC Questions And Answers 10 August 13th, 2008 08:27 AM
Downloading Allen Bradley PLC Data to a Access Database bigvicfella LIVE PLC Questions And Answers 5 January 25th, 2007 12:31 PM
