plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 31st, 2012, 11:23 AM   #1
saias
Greece
saias is offline
Twincat ads error 1820
I am new with twincat and im trying to set up a programming environment for a cx1030. I have connected to the cx through system manager and when I am scanning for devices, although for de3vices appear, I receive the following error:
Adserror: 1820 (0x71c, 'ADS ERROR invalid class id')
I am not sure if thats a serious problem but my main iissue is that i can t see all of the IOs.
any help?
Old April 1st, 2012, 07:51 AM   #2
Archie
United States
Archie is offline
What devices appear? What power supply is connected? What terminals do you have connected?
__________________
Expectations lead to disappointment. Appreciation leads to satisfaction.
AdvancedHMI - HMI Software without the license key hassles
Old June 21st, 2012, 04:57 AM   #3
PHe
Finland
PHe is offline
I have a simular problem as saias.
I also get an error "Init2\IO: Create TcomObj SAFEOP >> Adserror: 1820 (0x71c, 'ADS ERROR invalid class id')" while scanning devices.
I have cx1010-0112, cx1100-0004, 2xel1002 and el2004. Error comes while scanning "EtherCAT" device, and also when scanning related boxes.
Old July 31st, 2012, 04:11 AM   #4
Muhammad Lutfi
Indonesia
Muhammad Lutfi is offline
I have the same problem with Saias, how to solve this?
Old September 21st, 2012, 01:27 AM   #5
kudapucat
Australia
kudapucat is offline
Every time I have received this error I have found it to be because there is no EtherCAT on the port it's looking for.
This is a windows issue. You need to get your ports right and then beckhoff will behave.
ie on a running system, the port has been disabled (usually by some numpty who notices the windows "limited connection" error msg)
Or the cable is broken, or unplugged etc.
on a new system, it's generally because the port is plugged into a ethernet network. Swap the cables so the ethernet network is on the second port.
DHCP is generally enabled on both ports, so your PLC will respond to you no matter how you plug it in. EtherCAT however is generally only available on the first port.
Old September 21st, 2012, 02:02 AM   #6
kudapucat
Australia
Or, as in the case I'm hunting down today which has led me here, I'm told it's a version issue with TwinCAT.
Make sure your release is the same as the PLC you're programming.
ie I'm running 2.11 (1552)
the CE box I'm talking to is running 2038
The release is referred to by the first digit of the build.
I'm running release 1xxx CE 2xxx so I'll upgrade and confirm it works.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Beckhoff - twincat problem (newbie) titi_nicolas LIVE PLC Questions And Answers 22 July 31st, 2018 01:14 AM
TwinCAT EtherCAT Help Needed sujal.sheth LIVE PLC Questions And Answers 13 February 4th, 2015 10:19 AM
Beckhoff ADS .NET Communicatiom addicted LIVE PLC Questions And Answers 10 January 19th, 2012 10:16 AM
TwinCat PLC Remote Connection gouch LIVE PLC Questions And Answers 10 March 8th, 2011 03:44 AM
RSView32 ADS Workgroup/Domain tvich LIVE PLC Questions And Answers 0 November 11th, 2009 12:01 PM
