plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 1st, 2012, 09:37 PM   #1
Clark0325
Taiwan
Clark0325 is offline
Can MicroLogix 1400 communicate with EtherNet/IP adapter?
My company perchased a "MicroLogix 1400" to verify the connection with our
"EtherNet/IP to Modbus gateway", which is use as an EtherNet/IP adapter while
The MicroLogix 1400 is an EtherNet/IP scanner.
Here are my problems:
1 I have notice a comment on website of ML1400 says “allows controllers to exchange data with other controllers through messaging; does not support scanning of I/O on Ethernet adapters”.
Does it means MicroLogix 1400 cannot act as an EtherNet/IP scanner and work with an EtherNet/IP device which acts as an EtherNet/IP adapter?
2 I tried to setup the MSG block on RSLogix 500 to communicate with our module and always get "Invalid data type" error. No matter what data type I select. And of course I can't connect with our module.
Old April 1st, 2012, 10:06 PM   #2
Mark-
United States
Mark- is offline
Hello,
IIRC, the Micrologix 1400 uses PCCC not CIP.
__________________
Good luck,
Mark
PeakHMI
Old April 1st, 2012, 11:38 PM   #3
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Are you manufacturing this device, or are you testing something made by another company ?
I'm not going to describe all of EtherNet/IP in a Forum post: you can get that from the ODVA. But I'll hit the highlights.
In general, MicroLogix and SLC family controllers perform PCCC functions that are transported by CIP. PCCC is a protocol used mostly for older (PLC, SLC, and MicroLogix) controller data table reads and writes, rather than for I/O exchange.
ControlLogix family controllers (including CompactLogix) use EtherNet/IP differently; they not only perform CIP data table reads and writes, but also perform cyclic I/O connections using EtherNet/IP.
The technical name for devices participating in I/O connections on EtherNet/IP are Client and Server, or Target and Originator.
The terms Scanner and Adapter are commonly used to describe the hardware, but are not the proper technical terms for EtherNet/IP protocol roles.
The MicroLogix 1400 does have the ability to perform a CIP Generic Message to read and write the Assembly Object of a CIP device, but the connection is still an explicit message connection, not a cyclic I/O connection.
Some devices will work identically with an explicit or a cyclic message connection to the Assembly Object. Many will not.
To properly test a device that is intended to work with ControlLogix and CompactLogix, you need to use a ControlLogix or a CompactLogix.
__________________
"Intelligence is the capacity to know what we are doing and instinct is just instinct. The results are about the same."
Old April 2nd, 2012, 04:27 AM   #4
Clark0325
Taiwan
Well, I am manufacturing this device and just want to figure out if our device can work properly with AB's PLC.
I had already test my device can properly work with a ControlLogix and its EtherNet/IP module which we borrow from other company. But eventually my company bought MicroLogix 1400 for it is much cheaper than ControlLogix.
And I soon realize they are totally different...
My device did support "explicit message connection". So do you mean there got to be some way to read/write data to my device?
Anyway, thanks for answering my questions.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Micrologix 1400 + Panelview 550 + DH485 alexbeatle LIVE PLC Questions And Answers 2 September 13th, 2011 10:30 AM
micrologix 1400 and barcode scanner irondesk40 LIVE PLC Questions And Answers 0 August 17th, 2011 12:04 PM
MicroLogix 1400 Network seaston_65 LIVE PLC Questions And Answers 2 July 15th, 2011 12:57 PM
Micrologix 1100 and Ethernet/IP barcode reader SCUBA NooB LIVE PLC Questions And Answers 2 June 11th, 2011 09:20 PM
Micrologix 1400 and RSLinx 2.54 Tharon LIVE PLC Questions And Answers 7 April 28th, 2011 08:26 AM
