This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
port replicators
Does anyone know if using a port replicator will allow me to configure my (serial portless) laptop to use the serial port on com1? I have a usb adaptor, but on my laptop it gets added in on com5, which isn't supported by some applications. I'm using a keyspan usb adaptor, which in all other respects seems to work very well.
__________________
"If beating your head against the wall doesn't work, try banging a little harder. It won't help you any, but at least I'll be amused" |
#2 |
Normally, the USB adapter will get assigned the next available COM port. Open up device manager and expand the "Ports (COM & LPT)" to see what COM1 thru COM4 are currently used by.
If COM1 is in use, you won't be able to assign a USB port replicator to use that port either. If you're referring to a factory type port replicator (non-USB), then it may be another story... ![]() beerchug -Eric |
#3 |
Sorry, should be more clear. Yes, that is what I am referring to. I have a Compaq Evo, and I was curious if their port replicator(which plugs into the connection on the buttom of the laptop) will use it's serial port on com1. When I open my device manager, com1's location is listed as being on the Extended IO Bus. I think!? that means it is reserved for the connector for port replicators/docking stations, etc. I was thinking about buying their (compaq) port replicator/portable docking station, and I was wondering if anyone else is currently using a port replicator.
__________________
"If beating your head against the wall doesn't work, try banging a little harder. It won't help you any, but at least I'll be amused" Last edited by tom_stalcup; February 11th, 2004 at 08:44 PM. |
#4 |
I would think that style replicator would give you a TRUE serial port (and probably be COM1 as well!). Don't rely on my opinion though. Someone here probably has an EVO and docking station and can confirm this.
beerchug -Eric |
#5 |
I had the same problem with an IBM thinkpad,i got a thinkpad replicator with a serial port and was able to configure the serial port as com 1. |
#6 |
I picked up a compaq port replicator for my compaq evo laptop and configured everything fine on com1. I tested my (antiquated) 1747 pic box adapter successfully as well. I generally use the adaptor for my pcmk card for the dh-485, but I needed the serial com drivers for some of our dos based servodrive programs. Only problem is, the port replicator cost about $250.
__________________
#7 |
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Contrologix serial port | bobwithdana | LIVE PLC Questions And Answers | 2 | August 14th, 2004 10:08 AM |
| DL-06 comm port extravaganza | LIVE PLC Questions And Answers | 10 | March 1st, 2004 01:37 PM | |
| PC com port to S5 programming port (scada ) !! | ayman metwally | LIVE PLC Questions And Answers | 6 | January 27th, 2004 09:06 AM |
| RS-232 Port on SLC 5/03's / 5/04's | Dave McGlynn | LIVE PLC Questions And Answers | 9 | May 15th, 2003 08:55 PM |
| Reset port configuration on SLC5/03 | jvdcande | LIVE PLC Questions And Answers | 2 | May 15th, 2003 09:53 AM |
