plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 12th, 2012, 02:51 AM   #1
Andreik
Philippines
Andreik is offline
Simultaneous Read/Write (CP1E ModbusRTU)
Good day,
I have a problem with Modbus-RTU. In fact I'm new in this one and having slow progress grasping it. I'm using Omron "CP1E-N60DT-D" connecting to Oriental Motor "ARD-KD".
I've understood how to Read/Write data one at a time during my tests. However, in application, I need to Read(03h) and Write(06h) at the same time (like our usual PLC I/O's) but I can't imagine how to do it.
By the way I'm using "CP1W-CIF11". I've read something about the built-in RS232C port capable for Modbus-RTU but I'd never found any technical data regarding this or is it possible to use 2 ports at the same time.
I'd appreciate any help I can get. Thank you very much.
Sincerely,
Andrei K.
Old April 12th, 2012, 07:25 PM   #2
Andreik
Philippines
Andreik is offline
up
Old April 12th, 2012, 09:23 PM   #3
Andreik
Philippines
Andreik is offline
Please see attached
Old April 12th, 2012, 11:33 PM   #4
danw
United States
danw is offline
danw's Avatar
It can not be done, unless both devices have the capability of running two Modbus separate Modbus routines simultaneously, each routine having with their own comm ports.
It seems like you've already discovered that Modbus is a Master-Slave protocolm where a message from the master to the slave can have only one function/command code. Since any given function/command code is either a read or a write instruction, and there is no function code that combines the two, a Modbus operation is either read or write.
Your idea of paralleling ports will not work because the slave drive has only the one port. Even if you could somehow configure the master to read on its one port and write on its other port at the same time, that would create a bus conflict, with two masters fighting each other on a single bus line (which is why one of the Modbus RTU RULES is that only one master is allowed).
Old April 13th, 2012, 12:03 AM   #5
Andreik
Philippines
Andreik is offline
I see, guess I have to choose either to command or monitor the Slave. Thank you very much for the input, now I should be able to move on.
Old April 13th, 2012, 12:24 AM   #6
KalleOlsen
Norway
KalleOlsen is offline
The function code 23 is 'bidirectional'. I.e. you send and request data with one telegram. I don't think it is supported by all Modbus equipment. I've used it with Wago PLC and Vacon VFDs running ModbusTCP.
Kalle
Old April 13th, 2012, 02:04 AM   #7
Andreik
Philippines
Andreik is offline
It doesn't support that in this case.
Guess I really have to choose 1 of the 2. Thank you very much.
Quote:
Kalle
Old April 13th, 2012, 02:18 AM   #8
BobB
Australia
BobB is offline
BobB's Avatar
You can read and then write but have to program the two operations in the PLC - only one at a time.
__________________
The Old Pfhaart
Old April 13th, 2012, 04:04 AM   #9
Andreik
Philippines
Andreik is offline
@BobB,
It can't handle fast transitions though. And the data are jamming like party.
Old April 13th, 2012, 08:42 PM   #10
lostcontrol
New Zealand
lostcontrol is offline
lostcontrol's Avatar
Quote:
Originally Posted by Andreik View Post
@BobB,
What do you mean by fast transactions? What sort of speeds are you expecting with modbus Serial?
There is no need for the data to be jamming like a party if the code is executed correctly.
We have tried to give you plenty of help & lead you in the right direction...
Old April 15th, 2012, 09:01 AM   #11
danw
United States
danw is offline
danw's Avatar
The function code 23 is 'bidirectional'. I.e. you send and request data with one telegram. I don't think it is supported by all Modbus equipment. I've used it with Wago PLC and Vacon VFDs running ModbusTCP. Kalle
That's right. I'd forgotten about 23 because it's so seldom implemented. Interesting to know that Wago/Vacon supports it.
Old April 15th, 2012, 02:05 PM   #12
lostcontrol
New Zealand
The last time I looked at or used the 23 code, I found it quite slow compared to individual read/writes... but that could of been to do with the slave device also
Old April 15th, 2012, 02:14 PM   #13
KalleOlsen
Norway
Do you happen to remember which device it was, and if it was UDP, TCP or serial?
Just curious,
Kalle
Old April 15th, 2012, 02:23 PM   #14
lostcontrol
New Zealand
Was a Altivar 31 I think, Modbus Serial.
I can try & dig up the application to see what way I left it if that helps?
Old April 15th, 2012, 03:14 PM   #15
KalleOlsen
Norway
Thank you, but you don't need to do that. When we use Altivar, it is with Profibus.
Kalle
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
MSG read/write versus HMI read/write - most efficient rguimond LIVE PLC Questions And Answers 7 January 6th, 2010 05:32 PM
FT View read/write Controllogix mapping PLC5 data files? wilsonzhu LIVE PLC Questions And Answers 0 April 11th, 2008 01:44 PM
fishenguy fishenguy LIVE PLC Questions And Answers 54 November 13th, 2007 08:33 PM
1769-hsc Bob O LIVE PLC Questions And Answers 4 December 23rd, 2004 05:23 AM
