plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 25th, 2012, 11:18 AM   #1
Miuko
Slovakia
Miuko is offline
Step 7 - analog to real value problem
I am try to do this task:
write FC1 that would read from analog input (analog input = tw). The output of the FC1 will be downloaded/read/recorded in the format REAL. The output should be normed in the interval himin and himax that is connected with the input values of the model with analog inputs.
FC1 will have 3 inputs read from analog entry,himin, himax.
In the picture you can see my FC1. It is called from OB1.
http://imageshack.us/photo/my-images...nshot260d.jpg/
My problem is that from what I have tested, it is working very strangely - I get weird numbers.
examples-
tw=2
himin= changed automatically to 512!
himax=100
output= 1120407388
Do you see what can be the problem?
Thank you for any help!
Miro
Old June 25th, 2012, 12:48 PM   #2
oldnerd
United States
oldnerd is offline
oldnerd's Avatar
Not 100% sure but sounds like the scale is way off.
__________________
"Keep it simple."
Old June 25th, 2012, 01:11 PM   #3
juanmdx
Mexico
juanmdx is offline
I guess you should do something like this:
t1 := WORD_TO_INT(tw);
t2 := INT_TO_REAL(t1);
t3 := t1/27468; //here you have the value in a 0 to 100 scale
t4 := 100/himax; //get the convertion factor for your scale
t5 := t3/t4 + himin //now youo have it int a himin to himax scale
Hope this can help you, I don't know why your min and max values are changing (you said they are readed from an input), so maybe that's messing your program also.
Old June 25th, 2012, 01:34 PM   #4
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
Copy/paste the text from the SCL editor into your post - it is really quite tedious having to enter code from a screen shot. E.g.
Code:
FUNCTION fc111:VOID
VAR_INPUT
    himin:INT;
    himax:INT;
    tw:WORD;
END_VAR
VAR_OUTPUT
    ti5:REAL;
END_VAR
VAR_TEMP
    ti:INT;
    ti2:REAL;
    ti3:REAL;
    ti4:REAL;
END_VAR
BEGIN
ti:=WORD_TO_INT(tw);
ti2:=INT_TO_REAL(ti);
ti3:=ti2/27648;
ti4:=ti3*(himax-himin);
ti5:=ti4 + himin;
end_function
You also need to post the call in OB1 - without that we are blind. At a guess though, you are using M flags as the parameters to the FC and you have chosen MW's and MD that overlap.
Old June 25th, 2012, 02:05 PM   #5
L D[AR2,P#0.0]
United Kingdom
When you are monitoring code, you can chose the format for the display. You are showing the result in decimal format. Right click on the variable and select floating point (or automatic)
Old June 25th, 2012, 02:35 PM   #6
Miuko
Slovakia
Miuko is offline
OK sorry next time I will do it.
Yes that was one of the problems. The other was that I used close Bytes (now I am reading that you found out also this! ), so it was manipulating himin when I changed himax - for each it is needed 2 bytes and I used PEW256 and PEW257 so it was overriding!
Thank you very much for support!
Quote:
Code:
FUNCTION fc111:VOID
VAR_INPUT
    himin:INT;
    himax:INT;
    tw:WORD;
END_VAR
VAR_OUTPUT
    ti5:REAL;
END_VAR
VAR_TEMP
    ti:INT;
    ti2:REAL;
    ti3:REAL;
    ti4:REAL;
END_VAR
BEGIN
ti3:=ti2/27648;
ti5:=ti4 + himin;
end_function
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ABB Active analog problem Aburke LIVE PLC Questions And Answers 8 May 15th, 2012 07:11 PM
Omron Analog input problem abot LIVE PLC Questions And Answers 4 April 16th, 2012 04:05 PM
Analog card F408AD from automation direct....problem trubleshtr LIVE PLC Questions And Answers 1 September 1st, 2009 12:10 PM
Step 7 Real to DINT Ranjith LIVE PLC Questions And Answers 4 June 15th, 2007 04:32 AM
Urgend Step 7 programming problem Combo LIVE PLC Questions And Answers 8 August 24th, 2003 11:23 PM
