plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 5th, 2012, 09:53 AM   #1
sanger
Canada
sanger is offline
CompactLogix controller with Two Ethernet Ports?
Do any CompactLogix controllers exist with dual Ethernet built in or the ability to add a second Ethernet port as an add-on?
Old July 5th, 2012, 10:05 AM   #2
joseph_e2
United States
joseph_e2 is offline
The newest series has dual Ethernet ports. They also have a USB port for programming.
Here's their selection guide.
Edited to add:
Note that, as far as I can tell, the CPU does not support multiple IP addresses. It looks like the L4x processors support a 1769-ENBT module. Without digging in too much detail, the selection guide appears to indicate that the L4x do not have the on board Ethernet port(s).
Old July 6th, 2012, 08:20 AM   #3
kamenges
United States
kamenges is offline
kamenges's Avatar
As joseph_e2 indicated the CPX with two ports only has one IP address. The dual ports are a built-in mini-switch intended to support the DLR (??dual loop redundant??) topology.
To the best of my knowledge, if you need two IP addresses and you want to stick with CPX you need to go with an L4X processor and use two 1768-ENBT modules.
Keith
Old July 6th, 2012, 10:38 AM   #4
Chuck Woodbury
United States
Chuck Woodbury is offline
Chuck Woodbury's Avatar
I replaced a L35 with a L43 to accomplish just this.
The two ethernet cards mentioned above attach to the 1768 buss left of the processor. You will need a new power supply also, which attaches left of the ethernet modules. Works great to keep a local ENET/IP Control system seperate from the LAN and still have remote access to the controller.
__________________
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. - Douglas Adams
Old July 11th, 2012, 04:58 AM   #5
Andrew_Miky
Brazil
Andrew_Miky is offline
ENT Module
For your problem ENT modules is best solution if you require two different IP. As already stated above by experts
Old August 10th, 2012, 06:50 AM   #6
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
If you need to connect one controller to dissimilar ethernet LANs, then a router could be the solution without having to exchange the controller.
__________________
Jesper
3 strikes and you're out
Old August 10th, 2012, 07:12 AM   #7
WildeKurt
United States
WildeKurt is offline
We had to switch from an 3x to a 4x CLX processor for just that reason. Due to poor network design (or lack thereof) we'd have occasional outages which would disrupt control traffic. Isolating the two networks was our 'short term' answer untill IT could sort the network out. The best solution may be, however, a high level managed switch that supports VLANS and such (this is actually Rockwells recommendations). Properly managed, this will give you the greatest flexibility. The problem with two seperate networks is that there isn't anyway to bridge between the two ethernet cards efectively isolating you from any remote diagnostics.
Old August 10th, 2012, 02:15 PM   #8
The Plc Kid
United States
The Plc Kid is offline
The Plc Kid's Avatar
Quote:
That's not 100% correct. With a layer 2 switch and VLAN's that are not in the same subnet this statement is true but if you have a layer 3 switch then you can have traffic from you laptop reach everthing on the plc side for diagnostic purposes such as pinging devices and the webpages of the plc's and drives. You can remote control HMI's this way also but with the routing setup correctly these devices will only pass traffic to you laptops or engineering stations and not the rest of the network.
Also you never want automation devices on a corporate network even if IT can "work it out" and make it work. This is by default a very bad practice and will cause you issues. Not a question of if it will cause issues but when.
Old August 10th, 2012, 02:21 PM   #9
WildeKurt
United States
My point was that if you have two NIC cards in a CompacLogix you can not bridge between the two networks. The preferred method is using a Layer 3 switch.
This is contrary to Rockwells recommendations regarding EthernetIP Properly managed with VLAN's and such.
Old August 10th, 2012, 02:45 PM   #10
The Plc Kid
United States
My point was that if you have two NIC cards in a CompacLogix you can not bridge between the two networks. The preferred method is using a Layer 3 switch..
Sure you can. With a layer 2 or 3 switch depending and by varios other methods. Not a good practice but canbe done.
Rockwell has never advocated placing your automation devices on the same logical network as your corporate network. We are talking logical networks here not physical. Physical can be the smame or seperate your choice. IMO the physical needs to be seperate and only connected at one specific point. This is a common best pactice in any IT enviroment. Isolation is a good thing but it needs to be controlled isolation.
Old August 10th, 2012, 03:05 PM   #11
WildeKurt
United States
If you know of a way to bridge between two CompactLogix Ethernet cards without physically attaching the two networks please share.
That's what I just said.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
compactlogix ethernet messaging? dginbuffalo LIVE PLC Questions And Answers 17 March 10th, 2015 04:13 PM
Non - AB Protocol Send / Receive on Ethernet in SLC / CompactLogix PMCR LIVE PLC Questions And Answers 2 June 17th, 2010 06:17 PM
CompactLogix Ethernet card status gluca LIVE PLC Questions And Answers 5 July 16th, 2009 04:32 AM
Using a RADES9300 and serial ethernet to connect to plc...Works over eth but not dial bdoub1eu LIVE PLC Questions And Answers 5 July 28th, 2006 08:30 PM
Graphic Logic Controller (Xycom) Ethernet Q? SE Mana LIVE PLC Questions And Answers 1 June 26th, 2002 11:18 PM
