This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Hello!
I wonder if someone here is familiar with the Simens Moby I (RFID)system? I'm trying to write 50 bytes to an MDS403 (8Kb) memory tag over an ASM450 unit controlled from a 316DP2 CPU, but so far it only allowes me to transfer 30 bytes. As soon as I pass that limit it'll report the following error: -> Input or output areas are too small for the telegram length used. -> Read or write command with excessive length used -> Adjust bus configuration of the master module. I have used the same system with the same code to read / write 50 bytes of data before, the only difference was that I used a 413 CPU in that application. Anyone have som toughts about this? Regards Borte
__________________
Failure is not an option |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Siemens Profibus To Micromaster 440 | jimdi4 | LIVE PLC Questions And Answers | 17 | June 25th, 2011 01:09 AM |
| Acces Siemens S7-315 by VB | GAEvakYD | LIVE PLC Questions And Answers | 13 | October 14th, 2008 09:29 AM |
| Siemens S5 cpu problem | MagCarb | LIVE PLC Questions And Answers | 13 | June 15th, 2007 07:34 AM |
| Problems with Siemens MMC cards | RMA | LIVE PLC Questions And Answers | 8 | November 24th, 2006 02:52 AM |
| Siemens S7-313 to OP270B Communication | qee | LIVE PLC Questions And Answers | 4 | December 18th, 2003 06:40 AM |
