plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 15th, 2004, 07:42 AM   #1
Sameh
Syria
Sameh is offline
Sameh's Avatar
Fancy Exclamation Need Help Omron
need help
hi all
I have plc omron (cpu CQM1H)
I used with a system many Digital inputs many Digital & analog outputs
one Digital output module has Dameged I replace with a new one
after that the analog output which control the frequncy of many inverters was STOP & this is the problem.
Old March 15th, 2004, 07:57 AM   #2
Jay Anthony
United States
Jay Anthony is offline
Jay Anthony's Avatar
Did you replace the digital output module with the exact same type?
Did you put the output module in the exact same order?
If not, the addressing is different for the whole system.
Old March 15th, 2004, 08:08 AM   #3
Sameh
Syria
Sameh is offline
Sameh's Avatar
thanks Jay Anthony
but I replace the digital output module with the exact same type
&I put the output module in the exact same order.
Old March 15th, 2004, 10:42 AM   #4
Jay Anthony
United States
What's the module address for the DA002?
Old March 15th, 2004, 11:23 AM   #5
ArikBY
Israel
ArikBY is offline
ArikBY's Avatar
Jay
What you mean DA002. I never saw this term.
__________________
Arik
Barak Control Israel
Old March 15th, 2004, 01:36 PM   #6
Jay Anthony
United States
Ok, sorry...
CQM1-DA021
Old March 15th, 2004, 09:04 PM   #7
Vicente Jasareno
Philippines
Vicente Jasareno is offline
Maybe the PLC is in PROGRAM mode
Dear Sameh,
I was reading the operation manual of CQM1H (catalog no. W363-E1-2), Section 6 describe the DIP switch settings of CQM1 PLC. I found out that there is DIP switch setting (pin 7) that determine the operation mode of CQM1 upon power up of the PLC. base on the manual, if no device was connected to the PLC (for example hand-held programming terminal) and pin 7 is off on power up the PLC will be in PROGRAM mode but if pin 7 is on, on power up the PLC will be in RUN mode.
If the PLC is in PROGRAM all outputs are disabled.
see the link below for your reference
http://www.trascon.ru/dynamic/manage...s/w363e1-2.pdf
Old March 16th, 2004, 08:02 AM   #8
Sleepy Wombat
Australia
Sleepy Wombat is offline
Sleepy Wombat's Avatar
Did you put the CQM1-IPS01 OR CQM1-IPS02 back on the system and connect it also ?
Old March 16th, 2004, 08:41 AM   #9
Sameh
Syria
Sameh is offline
Sameh's Avatar
Jay Anthony
I am using CQM1H-CPU51
Vicente Jasareno
the pin7 is on & all machine is runing , the analog outputs are not effective & it's power led is on.
thanks for the PDF file I read it.
Sleepy Wombat
the system is running
thank's all .
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
communication b/n omron E5ZN temp controller with omron plc karikalan LIVE PLC Questions And Answers 1 February 23rd, 2010 01:52 AM
Wanted technical support for Omron PLC (Sysmac: C 60 K) kailashmariappan LIVE PLC Questions And Answers 0 December 1st, 2004 11:37 AM
Omron Plc c_gunner LIVE PLC Questions And Answers 8 February 22nd, 2004 11:38 PM
Omron NT 31C Programming -> NTST 3.3 Chris Rhodan LIVE PLC Questions And Answers 2 November 19th, 2003 04:53 PM
Omron 3F88L-132 rotory encoder (kinda like a PLC) Tough_Duck LIVE PLC Questions And Answers 3 June 15th, 2002 07:23 PM
