plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 21st, 2012, 07:26 AM   #1
tuxfather
Brazil
tuxfather is offline
FactoryTalk View ME Failed to initialize the service.
Hi everyone,
well, I'm having a problem with FT View ME at initialization.
Sometimes, when I'll open an existing project the FT crash, and this weird message shows up.
Most often this error occurs when I close and open the same project, but this is not a pattern, sometimes the error occurs, sometimes not.
My system is:
Windows 7 Professional (64-bits)
FT View ME 6.1
Old January 21st, 2013, 01:57 PM   #2
tuxfather
Brazil
Well, maybe no one has seen this error before... the fact is, this look like some ActiveX is missing on my system, because I have no reg for this CLSID.
If anyone has this reg on your computer in one of the directories below, please, try export and send the .reg
HKEY_CURRENT_USER\Software\Classes\CLSID\
HKEY_CLASSES_ROOT\CLSID\
HKEY_LOCAL_MACHINE\Software\Classes\CLSID\
Thanks.
Old February 15th, 2013, 03:30 PM   #3
krux
Mexico
krux is offline
I am having exactly the same error message in the same situation.
Any fix on this?
Old February 15th, 2013, 05:34 PM   #4
Frosty
Ireland
Frosty is offline
Seen it a few times myself - a pc reboot usually does the trick to resolve it.
Old February 15th, 2013, 05:42 PM   #5
krux
Mexico
krux is offline
I tried that, and also the repair option from the installation but the error is still there.
Old February 18th, 2013, 08:01 AM   #6
tuxfather
Brazil
Yeah, reboot the pc works, but it's not the solution... anyway, according to an employee from rockwell Brazil, this error can be caused due to an activation failure, but even him is not sure.
Old February 18th, 2013, 07:29 PM   #7
sportster
United States
sportster is offline
sportster's Avatar
At home right now so I don't have the exact info.....
Search the AB knowledge base for the error you are seeing. This is a known issue and there is a downloadable patch to fix this issue.
On a side note, this same issue with FTView will also hose up FTAssetCentre.
If I remember when I get to the office in the morning I will post the AB KB number.
__________________
Old March 4th, 2013, 07:58 AM   #8
tuxfather
Brazil
Hi sportster, have you found the KB number?
Old March 4th, 2013, 08:54 PM   #9
sportster
United States
sportster's Avatar
461888
__________________
Old March 24th, 2013, 05:51 PM   #10
Donald Widdows
United States
Donald Widdows is offline
I am getting the same error message, but rebooting does not help and the fix in the Knowledge Base #461888 did not work. Any other suggestions?
Old March 24th, 2013, 06:14 PM   #11
OkiePC
United States
OkiePC is online now
OkiePC's Avatar
Giant bottle of Jim Beam and a 40oz. speaker magnet. Strap the magnet to the hard drive while the PC is running, pour yourself a triple and walk away...
Sorry, I shouldn't be so sarcastic to a new member.
Welcome to the forum.
I can't say for sure if I have seen that issue, but pretty much all the weird issues with my FctMeStudio v6.1 (in 32 bit vm) went away when I doubled the desktop heap.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old March 24th, 2013, 06:24 PM   #12
Donald Widdows
United States
I tried the Jim Beam part, that is why I am just posting it on Sunday night...
Old March 25th, 2013, 02:00 AM   #13
OkiePC
United States
OkiePC's Avatar
Yes, "desktop heap" folks...google it up...
We should get Dustin to write a desktop heap checker utility, and pack it together with the best patch roll up kit...
We can call it it Steaming Heap. Yes, I think Steaming Heap would make a perfect accompaniment to FctMeViewStudio.
Have you tried doubling up the amount of deaktop heap this steaming pile is allowed to use? I wanna say something like switching from 512 to 1024 fixed several of my "Tag database not found", inability to view tags I just viewed, and other sporadic errors.
EDIT: Check this out, Microsoft already has a bloatware version of Steaming Heap. Who woulda guessed?
http://www.microsoft.com/en-us/downl....aspx?id=17782
__________________
Old March 25th, 2013, 08:23 AM   #14
jmveerkamp
United States
jmveerkamp is offline
This always seems to work when I get the "failed to initialize" error.
-shut down FactoryTalk
-browse out to your project - C:\Documents and Settings\All Users\Documents\RSView Enterprise\ME\HMI projects\
-delete (or rename I just put "-delete" after filename) RDMDATA in the "cache" directory
-delete (or rename) .CAC file in "tag" directory
-Restart FactoryTalk.
Old March 28th, 2013, 09:05 PM   #15
Donald Widdows
United States
Unhappy
None of these things have worked...I finally trashed it and loaded FTView 7.0 and it also came up with the same error. I guess the problem is elsewhere.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
FactoryTalk View SE View Client smohamed LIVE PLC Questions And Answers 11 June 14th, 2015 10:19 PM
FactoryTalk View SE with Proficy Historian Gman22 LIVE PLC Questions And Answers 1 August 15th, 2013 04:52 AM
Running FactoryTalk View SE V5.0 to work with FactoryTalk Service Platform 2.40 ? alpine LIVE PLC Questions And Answers 15 December 15th, 2011 06:49 PM
FactoryTalk View and MS SQL Server Susanne LIVE PLC Questions And Answers 10 October 14th, 2011 11:18 AM
Beckhoff twincat SMTP supplement Pete:-) LIVE PLC Questions And Answers 5 December 12th, 2008 08:29 AM
