plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 6th, 2013, 02:37 PM   #1
Ali Sayghe
United States
Ali Sayghe is offline
Exclamation analog input in ladder logic
Hi all
I am trying write a program that has analog input from a pressure sensor in a thank that read the pressure sensor for low level and high level when the pump start filling up the tank the motor for gate valve is closed when the water reach the high level the motor for the gate valve will open so the input and the output is:
input I:0/1 from limit switch 1 to turn off the motor when its opening the valve
input I:0/2 from limit switch 2 to turn off the motor when its closing the valve
input I:2/1 analog input from pressure sensor
turn output O/0 when the signal from pressure sensor is low (111)
turn output O/1 when the signal from presser sensor is high (25000)
I have a 1769-IF8 Analog Input Card in a Micrologix 1500 system.
Old February 6th, 2013, 02:45 PM   #2
passwordg
United States
passwordg is offline
Hey, I did not understand what your question is.
Old February 6th, 2013, 03:05 PM   #3
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
Quote:
...Input I:2/1 [is] the analog input from pressure sensor.
Beacause you are using a 1769-IF8 analog module, I think this analog input should be at address I:2.1 or I:2.0. In other words, it must be a word address instead of a bit address.
Quote:
I am trying to write a program...
If you would print your program to a PDF file, or ZIP it to a compresed file, and post it here, I am sure someone can help with your problem.
Your action elements are simple and only two:
"CLOSE VALVE MOTOR" and "OPEN VALVE MOTOR". Put two rungs in your program for those Outputs, and you will have a place to start.
Remember, the Inputs do not control the valve, but instead your PLC outputs control the motor that controls the valve.
Old February 6th, 2013, 09:55 PM   #4
Ali Sayghe
United States
yes you right i am controlling the valve through the dc motor but my problem is i don't know how can i use less than and more than function to turn the motor whether closing if the level is low or opening if the level is high according to the pressure of the tank the value that indicate low level is 500 and the valve indicate high level 20000 am using the raw/proportional unit for the analog input card. I am using SCP for to scale the input
Old February 7th, 2013, 07:10 AM   #5
Anirban Hazra
India
Anirban Hazra is offline
Anirban Hazra's Avatar
Quote:
Originally Posted by Ali Sayghe View Post
..my problem is i don't know how can i use less than and more than function to turn the motor whether closing if the level is low or opening if the level is high according to the pressure of the tank..
The Logic in the Attached Image shows how to do the above with the I/O addresses provided by you in Post #1 and #4.
However, note that if your motor is very slow and the rate of filling is lesser than the rate of emptying through a partially opened valve then you will need to latch the "Open valve" output till it reaches the limit switch because the level may drop before the valve position reaches the limit switch and turn the motor off.
Inversely if your motor is very slow and the rate of filling is greater than the rate of emptying through a partially closed valve then you will need to latch the "Close valve" output till it reaches the limit switch because the level may increase before the valve position reaches the limit switch and turn the motor off.
__________________
Anirban Hazra
Real Time Engineering Pvt. Ltd.
Authorized Channel Partner
of Rockwell Automation
Click to Connect with me on:
Facebook
LinkedIn
Old February 7th, 2013, 07:12 AM   #6
iant
Australia
iant is offline
iant's Avatar
just a note
is the analogue 0~10V or 4~20 mA
because the min max scaling is different for the two
__________________
Give all the answers
- People seldom learn.
Guide People to the posibilities
- Their Answers will come easily.
- Their Knowledge will grow.
They will then teach others
Regards
Ian Trost
Old February 7th, 2013, 05:49 PM   #7
Ali Sayghe
United States
Thank you very much its really works and i attached the final program
Old February 7th, 2013, 11:47 PM   #8
Anirban Hazra
India
Glad to have Helped.
__________________
Anirban Hazra
Facebook
LinkedIn
Old January 3rd, 2017, 05:31 AM   #9
bkp.2162@gmail.com
India
bkp.2162@gmail.com is offline
hello,i am just beginners i am doin a project using plc ...my project is customer receive water from water tanker as per his daily rquirement up to 30 days....after 30 days he need pay amout of that..
how to process this through plc analog process..each day calculation of water amount
Old January 3rd, 2017, 06:34 AM   #10
iant
Australia
iant is offline
iant's Avatar
Simply start with the maths.
Then look at your sensing device/s
Analogue maybe.
Flow or height or weight.
Digital maybe.
Flow meter with pulse output.
how accurate do you need this.
Litres, mega litres or milli litres.
How fast do yo need the delivery rate.
Then finally
What Model / brand PLC are you going to use.
__________________
Regards
Ian Trost
Old January 3rd, 2017, 10:37 AM   #11
bkp.2162@gmail.com
India
sir my plc is micrologix 500. can u plz elaborate with programmable..
what is math logic..
its beginners thats why i am asking details..
plz share with program and algorithims
thanks
iant
Old January 3rd, 2017, 10:40 AM   #12
bkp.2162@gmail.com
India
sir iant
input r analog device... how to read pulse rate and how to store it and final output in liter/mega liter to convert plz explain
thanks
Old January 4th, 2017, 02:43 AM   #13
iant
Australia
iant is offline
iant's Avatar
There are many ways.
But I need to know what equipment you are going to use.
Otherwise I could be writing info for the next 10 years
__________________
Regards
Ian Trost
Old January 4th, 2017, 06:40 AM   #14
bkp.2162@gmail.com
India
just wait u sir i will detail u through a diagram and equipment details...
iant
Old January 4th, 2017, 07:03 AM   #15
bkp.2162@gmail.com
India
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
what should i do, my analog input cant read the analog value? kartika LIVE PLC Questions And Answers 0 September 9th, 2012 11:14 PM
Scalling for analog input module - SLC 5/04 ckchew666 LIVE PLC Questions And Answers 1 May 15th, 2008 09:31 AM
direct logic D3-04AD 4 channel analog input Nathan Hendrix LIVE PLC Questions And Answers 3 December 2nd, 2004 02:12 PM
Analog input issue! NoName LIVE PLC Questions And Answers 9 July 8th, 2004 04:10 AM
Micro Logix 1000 Analog input comparision mikewood LIVE PLC Questions And Answers 5 June 21st, 2004 12:41 PM
