plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 14th, 2013, 09:44 AM   #1
bright676
United States
bright676 is offline
5/04 Fault, flashing fault light
Some how I managed to mess up my 5/04 and rs linx. Now when I do auto config. the baud rate come in at 1200 instead of 19200.
I know that I hit the wrong setting when configuring a different project but I just dont know what one(s). Aparently I must have changed some thing in the processor but I cannot go on line at all to change any thing.
I have pulled the processor out and reset it by shorting the ground/vbb together for about 60 seconds, and that doesn't work.
It is supposed to be running on DH+ from my serial port on my tough book with a cp3 cable. I dont have a clue what to do next.
Old March 14th, 2013, 09:51 AM   #2
Buzzen
United States
Buzzen is offline
can u get online with other processors on the network?
Old March 14th, 2013, 10:07 AM   #3
dmargineau
United States
dmargineau is offline
dmargineau's Avatar
It probably wasn't "running on DH+ from my serial port on my tough book with a cp3 cable".
It was most likely running on Serial RS232 and was using a DF-1 RSLinx driver.
Verify the PC's Device Manager, Ports (COM & LPT), Serial Port configuration; I have a hunch that the PC COM Serial port's baud rate was changed to 1200 kbps; make it 19200 and note the COM X number assigned to the Serial Port.
Reboot the PC and then, within RSLinx, add a new RS232 DF1 Devices driver (SLC-CH0/Micro/Type)related the COM X port you have just modified the settings to.
Hopefully an AutoConfigure will bring up the faulted SLC within the RSWho interface.
Old March 14th, 2013, 10:33 AM   #4
bright676
United States
That didn't help, it wouldn't even set on 1200. Any other ideas?
Old March 14th, 2013, 10:42 AM   #5
bright676
United States
I just did a restore point and now I have a port conflic with another port even though there was nothing else plugged in. I deleted the other conflick. and still no luck
Old March 14th, 2013, 10:45 AM   #6
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Quote:
??? does not sound correct, your serial port will not talk DH+
If you are using a CP3 to your serial port you will be using DF1 driver, see here http://www.youtube.com/watch?v=QIu1AGUR4N8
The CP3 will be plugged into the DB9 port on the 5/04 and your serial port (COM1) most of the time the serial is COM1
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Old March 14th, 2013, 10:52 AM   #7
bright676
United States
wtf! This is crazy. But some how I managed to get a program loaded into it!. I wish that I new how.
I think I may have some cable management issues here and need to clean this mess up.(operator error)
Thanks for your help.
Old March 14th, 2013, 11:00 AM   #8
dmargineau
United States
dmargineau's Avatar
One thing to remember about a PC's Serial Port: it has the tendency to be "hijacked" by various applications/services, some running in the "background".
The most common issue is the presence of two configured DF1 RSLinx drivers, "fighting" over the COM port.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SLC 5/04 - HSCE2 problems - processor fault Robotroc LIVE PLC Questions And Answers 6 January 1st, 2012 03:08 PM
SLC 5/04 User Fault Routine IsaacC LIVE PLC Questions And Answers 2 January 27th, 2011 04:21 PM
5/05 enet fault light 2004sk4 LIVE PLC Questions And Answers 15 May 7th, 2009 08:03 AM
Bit shifting? tlvaun LIVE PLC Questions And Answers 17 December 5th, 2002 10:51 PM
PLC flashing alarm light or output zero1954 LIVE PLC Questions And Answers 4 October 17th, 2002 08:32 AM
