plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 7th, 2013, 06:56 PM   #1
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
S7 1200 memory cards (MMC)
Is there anything special about the 1200 MMC?
It maybe an error from my supplier but I got a quote today for a 2gb card (6ES7954-8LP01-0AA0) it cost more then the CPU $596.98 ... can I use any compact flash?
2GB is way over kill but it jump from 2MB to 2GB in the part numbers
Thank you!
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Old June 7th, 2013, 07:25 PM   #2
iant
Australia
iant is offline
iant's Avatar
cant help you . but the MMC cards have a 'Siemens format' and of course they are making their money with hardware instead of software like AB
__________________
Give all the answers
- People seldom learn.
Guide People to the posibilities
- Their Answers will come easily.
- Their Knowledge will grow.
They will then teach others
Regards
Ian Trost
Old June 8th, 2013, 05:07 AM   #3
BryanG
United Kingdom
BryanG is offline
Yes that silly silly price is right and you can't use a standard card because they don't work without the special Siemens files and Serial Number. I can understand them wanting a high quality card if you want to use it as a program card that the program runs from, but I can't understand the issue with a transfer card. I can help with some part numbers:
SIMATIC MC 2 MB 6ES7 954-8LB01-0AA0
SIMATIC MC 12 MB 6ES7 954-8LE01-0AA0
SIMATIC MC 24 MB 6ES7 954-8LF01-0AA0
I must have a play and see if I can partition a large card down to 24MB and then do a bit copy, as I have seen discussed for the older Siemens cards.
Old June 8th, 2013, 05:33 AM   #4
iant
Australia
iant is offline
iant's Avatar
personally after working in the Auto industry, durng my apprenticeship, I know that here is not much difference between manufacturers .
I would think that the main difference is the formatting not the manufacture.
I have seen parts labelled and stuck into rebranded boxes.
It may be that Siemens are fully German Engineered. but VIPA is produced by former Siemens Engineers - so.....
Who Knows.
We also Know that Siemens Clones are being made in China.
__________________
Regards
Ian Trost
Old June 8th, 2013, 08:37 AM   #5
JRW
United States
JRW is offline
JRW's Avatar
Thank you!
Mark
2 gig mmc for 1200?
Something doesn't sound right
Tell G Fanning you want a better price.
Old June 8th, 2013, 09:36 AM   #6
geniusintraining
United States
Thanks for the answers guy's... I think I will price out the smaller one's to see if I can save some money that way
This is for machine that is going down to Mexico that is normally AB ControlLogix and a PV+ that they are going to convert over to a 1200 with a KTP600, everything else that I price out for my customer looks great, this should save them $1000's by changing to Siemens, but when the flash card is almost the same price as the touch screen it just does not look right
Thanks again!!
__________________
Old June 10th, 2013, 03:07 PM   #7
BryanG
United Kingdom
BryanG is offline
OK, so I used Paragon Partition Manager and first deleted all partitions on a new SD card. The I went to Advanced / Partitioning and choose Copy Partition, I copied the exisiting SD card partition on to the new card and ended up with a functioning Transfer Card. My reason for doing this is because I don't like carrying around a thing the size of a stamp that costs 250.00. I wouldn't use it as a program card but am happy to try it as a Transfer card.
Old June 13th, 2013, 01:58 AM   #8
dudu_br
Romania
dudu_br is offline
Quote:
Hello BryanG. Can you upload the partition as an iso image, or something similar? I have a 1200 Siemens PLC with a forgotten password, and I need an empty Siemens transfer SD card. The thing is that I don't wan't to buy the expensive SD card from Siemens, and also, I don't wan't to "lose" the PLC . Please help. Thanks in advance.
Old June 13th, 2013, 02:20 AM   #9
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Quote:
The 4MB card is not expensive at all, and you should always have a few spare cards.
__________________
Jesper
3 strikes and you're out
Old June 13th, 2013, 02:37 AM   #10
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
GiT, I am curious what you need a 2GB card for.
I think that you will never need anything bigger than the 4MB card for an S7-1200 as long as you dont log a lot of data to the card.
To update the firmware via an SMC card, you need a 24MB card. And if the S7-1200 has firmware 3 or higher it can update newer firmware versions via the webserver, so no SMC card needed at all.
I think that the 2GB card is for when you have S7-1500 and a very big project, or you need to log a lot of data to the card.
__________________
Jesper
Old June 13th, 2013, 02:43 AM   #11
BryanG
United Kingdom
BryanG is offline
In my first test I had two card readers and just used Paragon to copy the partition from one to the other. I have done some more experimenting with Paragon and though I can backup an image of the partition I can't restore it. I think it is more a problem with Paragon than a fundamental issue.
At the moment my card is in a PLC during some testing, and so isn't available. Even when the testing is finished I wouldn't be happy uploading a copy of the card. I am not trying to stop Siemens making a profit, I am trying to protect my investment from accidental damage. Also the copy process means that the duplicate ends up with the same serial number as the original. As Jesper says a 2MB card is not that expensive.
I have had a try at clearing a Password protected PLC, and you have a problem that you can't clear the PLC until it is stopped but you can't stop it without the Password. I did notice one thing I haven't tried yet, clicking on MRES, I can't try it at the moment because of ongoing testing but it might be worth a try.
Old June 14th, 2013, 09:55 AM   #12
geniusintraining
United States
Quote:
Went with the 24MB, $252.00 USD better but still a lot for a flash card
I first went with the 2GB just because... I thought 50 maybe 75 dollars the best thing was to get the largest one just in case its needed, no idea the cost was that high
To all... thanks for the help and answers
__________________
Old June 14th, 2013, 10:41 AM   #13
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
It's all relative. I still think the 4MB card would have been enough, but i would also have taken the bigger card for my first project.
This thread had me go through old price lists, just out of pure curisosity.
A 'normal' MMC card for S7-300 is for example the 512kB card for approx. 200 .
Before that, a 'normal' MC card for S7-400 was for example the 256kB card for approx. 350 .
Before that, a 'normal' Memory Module for SLC500 was for example the 32kW module for approx. 200 .
Before that, a 'normal' EEPROM Module for PLC5 was for example the 64kW module for approx. 1000 .
Before that, a 'normal' EPROM Module for S5 was for example the 64kB module for approx. 700 .
The S5 EPROMs makes me remember the ticking from the UV-eraser and the smell of ozone. And sometimes you forgot to remove the little sticker over the UV window so you had to erase again for an hour or so. Thats when you had time to sit down and read the days faxes. (wipes nostalgic tear from eye).
__________________
Jesper
Old August 24th, 2015, 02:34 AM   #14
Cullentrey
Germany
Cullentrey is offline
Anyone who could share a dump of a 2MB SMC (6ES7954-8LC02-0AA0)?
I got a password protected s7-1200 and no siemens sd card ...
thanks in advance!!
Old August 24th, 2015, 05:46 AM   #15
adfox
Poland
adfox is offline
adfox's Avatar
https://www.helmholz.de/prod,80_81_82.html
They have S7 MMCs.
__________________
Regards
I'm still learning. If I'm wrong, please correct me.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
S7 300 mmc software image sm1220 LIVE PLC Questions And Answers 1 December 5th, 2014 06:17 AM
S7 mmc sm1220 LIVE PLC Questions And Answers 3 May 30th, 2013 08:27 AM
S7 mmc problem rQx LIVE PLC Questions And Answers 0 February 11th, 2011 01:24 AM
Siemens S7 200 Library Memory 504bloke LIVE PLC Questions And Answers 0 June 24th, 2007 02:35 PM
SLC 5/03 data loss andydaoust LIVE PLC Questions And Answers 1 October 10th, 2002 06:38 PM
