Micrologix 1200 Input filter
Preeya
Nov 2003
112
I have some questions about Micrologix input filter. I feel that the filter settings I made (on the IO configuration) are not taking effect. I use a Micrologix 1200 series C, I have 2 high speed digitals inputs on inputs 2 and 3. I changed the input filter to the lowest - 25 microseconds.
When I go to help on the (embedded) IO configuration it says " The input filter time can only be adjusted by the time your program is developed" What does this mean?
Also, does anyone know what the default input filter delay is? When I go to the drop down menu for the filter it says - default, 25, 50, 100 microseconds etc It doesn't say what the default is..
Thanks for your time!
Oh! I found on the knowledge base that the default for DC inputs is 8 ms.
But still I am trying to understand why my change doesn't take effect.
WHere do I find out the scan time?
I have a 1762-L24BWA microligix 1200 that gets an input from a proximity switch that is mounted near sprocket the prox picks up once per...
5,033
Hey guys, I'm having some trouble getting my Micrologix 1200 setup with a 1762-IF2OF2 analog input/output card. I am trying to use it to read...
2,913
Dear Sirs , Firstly i am new with using micrologix1200. my question is i have a 1762 IF-4 input module which is connected to my micrologix 1200...
8,464
I'm hoping that on of the PLC adepts can help me with this question. I am going to be taking an analog weight signal from an MMI and using it in...
8,715
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
604
