This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Guest
Posts: n/a
update rslinx to 2.4
Hi
I have rslogix 5.00 ver. with rslinx 2.2. Now i want to update rslinx from 2.2 to 2.42. My question is if have to uninstall the old ver. as specified on web or it will update old 2.2 ver.to 2.42 automatically. |
#2 |
![]() Join Date: Jun 2002
I have found it safer to uninstall the old version first. Make a backup of your configuration first.
#3 |
![]() Join Date: Jan 2004
i have found it better to uninstall the older version also
__________________
cavy |
#4 |
![]() Join Date: Sep 2003
I don't think the canned install routine will run without uninstalling first. That is certainly the case with Logix, though I can't say I ever tried with Linx. If Rockwell recommends uninstalling the old one first, that's what I think you should do.
Marc |
#5 |
If you use the canned installation routine it will ask if you want the older version removed. If you answer no to this it will not install the newer version. If you answer yes to this it will begin the uninstall routine to remove the older version. The next question or actually a statement to the effect "you may wish to backup your configuration file" or something to that nature, I would suggest make the back up and then restore the config data using the RSLINX utilities provided, it will save some time having to reconfigure all of the drivers.
Bitmore |
#6 |
I have RSlinx 2.20.02 installed on PC and I want to upgrade to version 2.4 ... my question is: Can I download this version free or I have to buy this?
and if I can download free ... where can I do it from? |
#7 |
You can download the "lite" version for no charge. Go to this LINK
You will be required to register, but that's all. Ken
__________________
"To give real service you must add something that cannot be bought or measured with money; and that is sincerity and integrity." - Donald A. Adams |
#8 |
The web update will probably give you 2.43. That's what I'm running. I think it makes you uninstall the previous version before the new one will even install.
#9 |
Isn't Linx 2.5 out? I got it on CD with the last purchase I made.
#10 |
Yes, 2.5 is current. That is what I would install.
RSL |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| RSLinx & DDE links | Danocane | LIVE PLC Questions And Answers | 4 | September 23rd, 2004 02:18 PM |
| Excel connection to RSLinx Gateway | poiuy | LIVE PLC Questions And Answers | 8 | October 14th, 2003 08:00 AM |
| how often should I trigger the PID? | Ron Beaufort | LIVE PLC Questions And Answers | 11 | February 22nd, 2003 10:57 AM |
| RSLinx 2.4 | Jiri Toman | LIVE PLC Questions And Answers | 5 | January 4th, 2003 11:01 AM |
| Start RSLinx Minimized/Verify RSLinx Running | zmanvortex | LIVE PLC Questions And Answers | 2 | May 3rd, 2002 10:43 AM |
