plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 12th, 2013, 11:04 AM   #1
ebolbol
United States
ebolbol is offline
FactoryTalk View SE 7.0 to FT View SE 5.10 Problems
Hello gents,
Have you ever ran into this? You have two versions of FactoryTalk View SE, one is 7.0 and the other one is a much older version 5.10
You've developed a whole bunch of new screens in the 7.0 you would like to export to the 5.10 and during the import, 5.10 gives you a whole bunch of import errors. When you try the "Add component into app" method (i.e. *.gfx files) you also get errors.
Yes why don't I just upgrade the 5.10 to 7.0... well... logistically it's complicated... as a main supervisory workstation, I'm not able to disable that machine any time soon... but long term, upgrade is in order.
any thoughts?
thanks
Old December 12th, 2013, 11:15 AM   #2
DBLD99
United States
DBLD99 is offline
It is pretty standard with most software you can take stuff that is created in a new version backwards. You could create the screens in 5.10 - then import them into 7.00.
Old December 12th, 2013, 11:30 AM   #3
ebolbol
United States
ebolbol is offline
FactoryTalk View SE 7.0 to FT View SE 5.10 compatibility
Quote:
yeah... at the time I made the screens I didn't think they would be as heavily used as they have proved, so I didn't build them on the main supervisory machine which is the 5.10... had I but known, I definitely would have done it on the 5.10 and exported them to the 7.0... now it's too dreadful to have to do all that again manually
there has got to be a way to convert the xml to be compatible with 5.10
Old December 12th, 2013, 10:43 PM   #4
leighigh
United States
leighigh is offline
Have you tried just opening the 5.1 with 7.0 then just copy the new screens to your Appication. Them When your done just save your run file as a 5.1 ver. then down load it to the HMI.
Old December 13th, 2013, 12:39 AM   #5
rdrast
United States
rdrast is offline
rdrast's Avatar
Quote:
SE isn't ME. It doesn't work that way.
The easiest thing is probably going to be simply recreate the displays in 5.1, and always edit on that platform from now on.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old December 13th, 2013, 12:56 AM   #6
ADoozer
Australia
ADoozer is offline
What errors are you getting?
My assumption is the errors relate to old/missing controls in V5.10... If this is the case you could try manually massaging the export xml file to "fix" the issue.
I have done this a few times while migrating between different production system versions (albeit never from V7). It's a pain in the *** but with a bit of playing it can be done.
(Ps I use XML Copy Editor for manipulating the XML)
Regards Dave
Old December 13th, 2013, 01:18 AM   #7
ebolbol
United States
ebolbol is offline
leighigh,
Well there is no HMI downloading involved here as this is Site Edition "stand-alone" that is resident on the workstation(tower) that it runs on.
I think once you open an older version, or copy it into the new application, it converts everything to the newer file structure and can't revert back. I will try what you said... I will copy a couple of GFX's from 5.1 to 7.0 folder in explorer and try to open from within Studio to see what it does...
Old December 13th, 2013, 01:23 AM   #8
ebolbol
United States
ebolbol is offline
rdrast,
I think you're right... even though RA can easily make newer versions backward compatible, it's a matter of economics and $$$ I'm sure... they want people to upgrade, which is fine.
Old December 13th, 2013, 11:59 AM   #9
ebolbol
United States
ebolbol is offline
Regards Dave
ADoozer,
I have Notepad++ and it allows me to edit XML
so initially I thought it was an easy change, when I got msg1 "Gfx-SE6.xsd' schema could not be found." I simply opened the XML file and changed SE6 to SE4 because that's how 5.10 xmls have. After doing that, I got msg2??? (both msg's attached)
File Type: txt error msg 1.txt (538 Bytes, 164 views)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Pop-Up Trending using FT View SE 5.00 specialkc LIVE PLC Questions And Answers 1 July 17th, 2014 10:24 AM
FactoryTalk View SE VBA user form rifem LIVE PLC Questions And Answers 2 October 28th, 2012 01:08 PM
FT View SE Display protection clownbrother2 LIVE PLC Questions And Answers 0 March 15th, 2012 02:07 PM
Scanner and FT View SE SMOKE LIVE PLC Questions And Answers 0 January 9th, 2009 03:11 PM
RSLOGIX5000 & FT VIEW SE SLOW BOOT introl LIVE PLC Questions And Answers 0 May 21st, 2008 07:45 PM
