![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Australian Control Panel Standards
I know there are a great number of members to this site from "down under". Perhaps one of you can help me.
My company is preparing a piece of equipment that is shipping to Australia. We are well versed in UL508A standards but want to make sure we meet those of Australia. My questions are: 1. Does Australia follow CE or other standards? 2. Will they accept UL508A? 3. Are there wire color standards that we should be aware? 4. I understand that the standard low voltage is 240VAC/1ph/50Hz. Correct? 5. High voltage standard. I understand this would be 480V/3ph. Correct? Thanks in advance.
__________________
...rab |
#2 |
![]() ![]() Join Date: Feb 2007
Low voltage is 230v 50Hz 1 phase (was 240v +/-6% but was changed to 230v +10% - 5%)
High voltage is 415v 50Hz 3 phase Alan Last edited by alan_505; January 15th, 2014 at 06:31 PM. |
#3 |
I believe you are going to need what is called "C-Tick" approval. It's a quasi-equivalent system to UL508A except that it's more related to EMC, kind of like having to get FCC approval for a control panel because it might emit RFI or EMI. Talk to your UL rep though, they may be able to offer it to you, for a fee of course.
And yes, the wire coloring system is different there, of particular note is that Neutral conductors are not white. Most of that however would be related to the FILED wiring, not necessarily your internal control panel wiring. |
#4 |
![]() ![]() Join Date: Jan 2014
Control panels would need to comply with Australian standard AS3439 and AS3000/2007 for colour coding and wiring standard
#5 |
They also need to comply with AS4024 (Safety of machinery) and AS3000 (Wiring Rules) as a basic minimum. There are standards for rotating machinery and for robotics that don't affect your panel directly, but may affect the design of safety and whatnot... And much more. You're best having a look at what applies to you.
http://www.standards.org.au/Pages/default.aspx 1) Australia follows AS:NZ Standards. 2) Some sections may be similar, but essentially no. 3) Many sites/clients have their own standards here, and they can differ greatly. The only firm rule is that you use Green, or Green/Yellow wiring for Earth. Also check to see what supply you're dealing with, as we use an MEN system here. 4) As above. 5) As above. Can you tell us anything specific about the equipment? Last edited by Jeev; January 15th, 2014 at 08:39 PM. |
#6 |
Jim1962 & Jeev ...
Thanks, this is very helpful.
__________________
...rab |
#7 |
Couple of things - earth is green/yellow - green will be rejected.
Phase colours are red, white, blue - neutral is black. There is no standard for LV wire colours but usually grey/black are used for 24VAC and the most common colours I see for 24CDV are orange/violet. Positive is the first colour. If you are supplying power to GPOs and lighting circuits they will have to be protected by RCDs rated @ 30ma trip. If the job is for a mine then there are a whole new set of rules.
__________________
The Old Pfhaart ![]() |
#8 | |
Quote:
Your AS3000 standard. Are the color codes and wire types defined for commercial wiring or industrial (like control panels). Here there are some differences. If this is the standard we should look to, then it appears not to be prohibitively expense and worth the cost. Is there a certification listing mark that inspectors look for? In the US no listing identification, by itself, has the rule of law except as referenced in local building codes. Standards (NFPA70, NFPA79, UL508A) available are suggestions that have been accepted as safe and recommended. Here they will try and find that the build has followed some recognized rules like those of UL (Underwriters Laboratories), specifically UL508A for panels. In Europe they look for CE conformance.
__________________
...rab |
#9 |
The cable should be solid colour not tape. That is not good practice as the tape can come off and then confusion reigns! The most important ones are black for neautral and green/yellow for earth. Green and/or yellow are not permissable at all except in small multicore cables - 30/40 core etc as used in some pre-made cables for PLC I/O blocks.
For single phase 240 volt red and black are the most common colours but the phase colour should match the phase ie white and blue are used as well. AS/NZ 3000 has colour codes in it and just about everything else. There is also a standard for standard symbols as well for myou drawings. We tend to follow IEC standards here pretty much but 'legacy' symbols are also allowed - and then there are the 'make your own' from a combination of symbols for something that is not defined. We do not generally look for compliance standards unless specified but generally use equipment that has CE certification - rarely get asked for UL. Hope this helps.
__________________
#10 |
"Or equivalent" - is stated in this standard
So your SIL ratings apply as well as EU safety standards ![]()
__________________
![]() Give all the answers - People seldom learn. Guide People to the posibilities - Their Answers will come easily. - Their Knowledge will grow. They will then teach others Regards Ian Trost |
#11 |
Thanks everyone ...
I think this gives me an understanding of the path I should follow in building my Austrialian version of our ICP (industrial control panel).
__________________
...rab |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
control panel designing | nazeeravt | LIVE PLC Questions And Answers | 2 | May 17th, 2012 12:33 AM |
Control Panel Building Tips : Back Panels | Tim Ganz | LIVE PLC Questions And Answers | 2 | May 7th, 2012 10:00 AM |
What are your current safety practices with control panel startup & debug? | tspisak | LIVE PLC Questions And Answers | 0 | July 27th, 2011 08:23 AM |
Australian wiring standards | g.robert | LIVE PLC Questions And Answers | 11 | October 12th, 2003 06:40 AM |
Do you think which software is very nice for design control panel? | Platootod | LIVE PLC Questions And Answers | 5 | July 16th, 2003 10:35 PM |
