plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 7th, 2004, 02:12 PM   #1
bbickett
United States
bbickett is offline
PKTX card driver
Hello! I installed an allen bradley pktx card on a work station with xp. It is recognized by the pc correctly, but I am unable to configure the driver in RSlinx. Error: Unable to open the device b/c the process map object could not be created.
I have changed the jumpers on the card, and tried changing the address in the configuration. Any help would be appreciated.
Old May 7th, 2004, 02:21 PM   #2
Ron Beaufort
United States
Ron Beaufort is offline
Ron Beaufort's Avatar
see if this helps ...
Link to Knowledgebase document P7152
__________________
2-B ?
Best regards, ----+----] [----+------------( )----
Ron | |
PLC Training Boot Camp | 2-B |
I once was lost, but now am found, was blind, but now I see.
Old September 28th, 2007, 11:23 AM   #3
jrs2563
United States
jrs2563 is offline
1784-PKTx card installation
I too am having a problem installing a PKTx card in a newer WinXP computer. I cannot get rid of the flashing green light. I'm using RSLinx 243. This started when I upgraded from an older win98 computer. It was working fine there. Computer device manager says the card is working fine. I thought maybe the card was bad and tried a new one, same problem. Any settings on my computer that may be comflicting? Thanks...Jim Schroll
Old September 28th, 2007, 12:32 PM   #4
jrs2563
United States
jrs2563 is offline
an older copy of XP pro, but with SP2 installed.
Old September 28th, 2007, 12:37 PM   #5
curlyandshemp
Canada
curlyandshemp is offline
curlyandshemp's Avatar
Quote:
There is one driver for Win98 and another for Win2K, XP
__________________
Work to Ride,
Then Ride to Work
I would rather have a bottle in front of me..
than have a frontal lobotomy
Old September 28th, 2007, 12:44 PM   #6
Mickey
United States
Mickey is offline
Mickey's Avatar
Driver may not be your problem. The blinking green lite usually means
your not connected. ( see pic). Check your connections, then check them again. ( termination resistors?)
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old September 28th, 2007, 02:37 PM   #7
jrs2563
United States
jrs2563 is offline
I did use the driver that was on the rslinx disk. Dont know if it makes any diff, but when you look at the driver from the hardware profile, it says no drivers are installed. Is that normal?
Old September 28th, 2007, 02:47 PM   #8
Marc
United States
Marc is offline
Marc's Avatar
Make sure you are configured as a pktx NOT a ktx. This will cause heartburn if the wrong config is used
Marc
Old September 28th, 2007, 06:08 PM   #9
jrs2563
United States
jrs2563 is offline
The configuration I am trying to do is connecting to channel 1A of a "master" PLC 5/40 which already has a field PLC 5/20 connected to it. I want to parallel right off there and go to my PC. I have not used a terminating resistor. Did'nt have one on the win98 computer previously.
I am using the pktx driver, although after installing it, in the hardware
profile it states that no drivers are loaded. Maybe thats normal. If not, then the driver isnt loaded but the procedure to load it from the disk apparently went normal.
Old September 29th, 2007, 03:26 AM   #10
Marc
United States
Marc is offline
Marc's Avatar
Have you tried "update driver" from device manager? I did this type of install recently and vaguely remember having to do something unusual. Good luck
Marc
Old October 1st, 2007, 05:22 AM   #11
jrs2563
United States
jrs2563 is offline
Yeah, tried updating the driver. Worked on it last nite, still left with a flashing green light. Guess Ill just keep pluggin away. Probably is something simple. Thanks for the help, guys! Jim
Old October 1st, 2007, 09:08 AM   #12
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
Then I bet you have the wrong one. Your RSLinx Version 2.43 disk may have been issued before the Windows XP operating system was even a gleam in Bill Gates's eyes. You need the "1784-PKTX(D) Win2K XP Driver". Uninstall your old driver and download and install this one:
1784-PKTX(D)_Win2k_XP.zip
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Simovert Masterdrive with T300 card Johnny T LIVE PLC Questions And Answers 4 May 31st, 2006 03:30 PM
PKTX Card installation on Win 2K JPCompounds LIVE PLC Questions And Answers 5 September 2nd, 2004 11:25 AM
1784-PCMK/B Card Health msinclair LIVE PLC Questions And Answers 6 August 13th, 2004 09:19 AM
AB PLC5, 1771 ife/C Card webbyjules LIVE PLC Questions And Answers 6 March 5th, 2004 12:39 PM
Seimens ISA MPI card driver pollypop LIVE PLC Questions And Answers 2 June 11th, 2002 04:11 PM
