plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 3rd, 2014, 01:18 PM   #1
Ffakury
Iran
Ffakury is offline
Exclamation Fault & restart AB SLC 5/04 periodically
Hi
Any one know how i can clear this fault?
Cpu run led turn on for a second then red fault led turn on for a second then cpu restart and all leds turn off and on. This routine happened periodically.
I remove ram battery and clear cpu ram but problem not solved. In program mode when i switch to prog. Just fault led turn on for a second and cpu restart again . Because of the cpu restarting periodically i cant communicate with that .
I remove eeprom and power on cpu , just the fault led turn on steady and cpu not restart more.
Old February 3rd, 2014, 01:46 PM   #2
Mickey
United States
Mickey is offline
Mickey's Avatar
If you can go online with the controller take a look at processor status- error tab and tell
us what the fault is (S:54) and its description.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old February 3rd, 2014, 01:50 PM   #3
Ffakury
Iran
Ffakury is offline
Unfortantly periodically restart not allow me to communicate with cpu. And question is why cpu restart periodically and not steady fault!
Old February 3rd, 2014, 01:52 PM   #4
Mickey
United States
Mickey is offline
Mickey's Avatar
Quote:
One of the more common issues is a faulty power supply. If you have another
replace it. Also grounding issues, check a double check your processor ground.
__________________
Mickey
Old February 3rd, 2014, 01:58 PM   #5
Ffakury
Iran
Ffakury is offline
Ok i will check ground , but do you have any documentation regarding pin configuration of cpu? My mean what pin is VCC or ground ?
Old February 3rd, 2014, 02:03 PM   #6
Ffakury
Iran
Ffakury is offline
And another issue is if power supply has problem why when i remove eeprom the cup goes to steady fault and not restart more?
Old February 3rd, 2014, 07:16 PM   #7
daba
United Kingdom
daba is offline
daba's Avatar
Ffakury....
Power OFF - Put the keyswitch to the PROG position, and power ON - what happens? (LED states)
Remove the EEPROM module, and again power ON with keyswitch in PROG position - what happens?
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old February 3rd, 2014, 09:13 PM   #8
Mickey
United States
Mickey is offline
Mickey's Avatar
See pdf
This procedure will clear the processors memory. Make sure you have a backup before doing this.
__________________
Mickey
Old February 4th, 2014, 12:35 AM   #9
Ffakury
Iran
Ffakury is offline
I switch to prog mode the fault led turn on one second and then cpu restart again . This happened periodically.
I remove eeprom and power on cpu the fault led turn on steady
Old February 4th, 2014, 11:33 AM   #10
Mickey
United States
Mickey is offline
Mickey's Avatar
See link below, chapter 10 troubleshooting guide.
http://literature.rockwellautomation...m011_-en-p.pdf
__________________
Mickey
Old February 4th, 2014, 11:53 AM   #11
Caveman
United States
Caveman is offline
Caveman's Avatar
How about trying this. Remove power, unseat all cards but CPU then power up.
Then hopefully fault will blink.
__________________
Farmer PLC Tech
Old February 4th, 2014, 04:22 PM   #12
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
So the SLC 5/04 PLC restarts with the EEPROM installed, but DOES NOT restart with the EEPROM removed? Most likely the S:1/10 bit is set in the Status file. That explains the restarting, but not what is the error.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AB SLC 500 major fault output? Jonas Zimmer LIVE PLC Questions And Answers 3 August 27th, 2013 11:36 PM
AB SLC 5/03 going to fault after power failure sns LIVE PLC Questions And Answers 13 January 24th, 2010 09:52 AM
slc 5/04 cpu fault and not output card power blamison LIVE PLC Questions And Answers 1 July 24th, 2009 11:39 AM
SLC 5/04 + 1747-SN,B passthru to Panelview paperboy4828 LIVE PLC Questions And Answers 2 March 2nd, 2007 02:18 PM
SLC 5/05 Ethernet hardware fault (A2h) Znatok LIVE PLC Questions And Answers 2 October 11th, 2005 11:26 AM
