AussieTow1
Hi forum readers. I am new to this forum and hope some of the knowledgable indiviuals can help me to resolve an issue.
I am recommisions a new robot facility with a SLC5/05 processor and Kuka robot. The system runs 2 devicenet networks. The robot is the master (node 00) and the SDN card (node 30 - on the PLC rack) is in slave mode. In the second network the SDN card (node 30 is the master) and we have a number of I/O modules off it. I am trying to send 30 bytes of information to and from the robot and PLC via the slave mode, polling the data and mapping it to the M1/M0 files (words - 15). The robot network is not faulting, but the SDN card is showing node 30 error 77. Node 00 is not in the scan list (because I want it to be the slave), and the I/O mapping appears correct 30 bytes (using RSnetworx in pass through mode). The networks used to work before I added I/O to the Wago units and an additional network module (encoder).
This has me stumped as the scanner scn lists and I/O maps look OK.Any ideas on the cause of this error, or pointer where to look?
