![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Jun 2014
Problem connecting from PC to ControlLogix PLC
Hello all,
I am having a hard time connecting to my ControlLogix PLC. I recently visited a plant and needed to set my wired network connection (IPv4) to "Obtain an IP address automatically." Now that I have returned to my office, I need to connect to this ControlLogix PLC. I set my IP address to a static address that exactly matches my PLC. If you look at my attachment, you will see that my 'test_bench' driver no longer recognizes a controller, but now recognizes a computer. I am out of ideas, and I followed my regular procedure in order to connect to the controller. Any help will be appreciated. I am new to this stuff so anything helps. |
#2 |
Set your computer so that the first three groups match but the last one must be different than the target PLC, and different than anything else on the network if connected to more than one device.
Set your 'netmask' to 255.255.255.0 This will satisfy many situations.
__________________
Controlling outputs is the PLC's way of getting its inputs to change. www.thePLCguy.com |
#3 |
Thanks for the reply but it's just not working for me. I tried it out but theres still a computer shown
#4 |
If the computer's IP is the same as the one you just set then the computer IS your computer.
Open 'Communications' then 'Configure Drivers' - take a screen shot of that The click on this last driver and click on 'Configure' - take a screen shot of that. Post both
__________________
Controlling outputs is the PLC's way of getting its inputs to change. www.thePLCguy.com Last edited by bernie_carlton; July 14th, 2014 at 06:28 PM. |
#5 |
I believe you have configured an "Ethernet Devices" driver in RSLinx, and specified your PC as the address you want to talk to....
correct me if i'm wrong... show us a picture of what you can see if you expand (click the + sign to the left) the Ethernet/IP driver called ABETHIP-1, Ethernet
__________________
___________________________ ![]() abtrain@tiscali.co.uk www.abtrain.co.uk tel: 07506 73 9999 nil illegitimi carborundem |
#6 |
well i finally got it to work. its hard to describe what i did in order to make this thing work. i can now talk to my controller and run a program with rslogix 5000.
i found that i had a 'LAN connection' and a 'VirtualBox Host-Only Network' in my network connections. I disabled the VirtualBox. I typed in a static IP address for the LAN connection that would go along with the PLC (10.59.8.xxx). When I looked at RSLinx i saw that my PLC appeared. I was trying to use this virtualbox connection the whole time. i think that might've been there because of some kind of training i did? anyways, thanks for the help. it's now running. |
#7 | |
Quote:
__________________
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Pc and plc coomunication problem | niyaz432 | LIVE PLC Questions And Answers | 0 | November 23rd, 2012 05:41 AM |
Allen Bradley ControlLogix 5000 PLC problem | VoltSmith | LIVE PLC Questions And Answers | 22 | January 16th, 2010 02:14 AM |
S7-400 communication PDV to PLC problem | TBMALEPPO | LIVE PLC Questions And Answers | 1 | March 9th, 2008 04:05 AM |
Connecting two PC adaptors to the same port on a S7-300 PLC | islman1975 | LIVE PLC Questions And Answers | 3 | February 1st, 2008 10:01 AM |
I/O Comm. problem btw PLC & HMI | WFox | LIVE PLC Questions And Answers | 7 | December 31st, 2003 01:09 PM |
