cable RS485 siemen
ngoclan
Sep 2013
vung tau
153
dear everybody
I'm not yes USB to RS485 converter cable, types: USB to RS485 converter cable connecting for plc siemen S7 300 and S7 200. to connect computer which plc
because my computer of me. it's haven't RS485 port
i see USB to RS485 converter cable, of siemen production it's too expensice.
i have little money, not enough to buy USB to RS485 cable of siemen production
can you help me
can you speak for me know.
can I use USB to RS485 converter cable of manufacturers different ? fix connect with PLC to PC ??
Be very carefull when choosing a cable: for S7-200 you can do with a simple USB-RS485 converter (aka USB/PPI cable) but for S7-300 this won't do. The USB/MPI cable you need for that does more than simple electrical level adaption, there's a microprocessor needed to take care of the protocol conversion, speed adaption and data buffering. Most (all?) cheaper cables are only fit for one family of Siemens PLC's, the official (more expensive) Siemens converter can do both PLC families at once.
BTW so far I've never seen a standard computer with an RS485 port, only dedicated ones from Siemens.
Kind regards and good luck,
thank you very much
have a nice day
I am going to daisy chain a couple Modbus devices off of a Click plc using rs 485. There will be three slave devices daisy chained off one another...
9,173
Hi all, I'm trying to get a bom together for an R&D project. I have modbus devices that require 355mA for power plus communications. Does anyone...
1,304
Hi, How do people terminate cable screens on RS485? I've been reading around and people seem to do various things. A few people have said you...
2,552
Hi I have been reading stuff online about the "characteristic resistance" of cable which is best for RS485. A lot of material says you should...
2,766
Hello, I am a little bit confuse on how to connect from MVI56-MCM port 1 to CS121 SNMP adapter for UPS using RS485 option. Which cable should I...
1,910
