How to check IGBT in siemens simovert vc drive
Amar88
Jul 2014
India
All Respected experts
I want to know to check igbt moduel of siemens simovert vc drive while input is connected to drive pls help me i am new in this field.
Thnx a lot
You do not. You can get killed. If an IGBT is bad, the drive will tell you that. If it does, there is no justification for working on it while the input is live.
Thnx for your support jraef .... can you provide me link for download manual of 6se7141-1eh62-3ba0-z
When drive is not powered and motor disconnected, you can do diode test across outputs. AB, BC, CA. You will read diodes in both directions. If any of the IGBT's are shorted, they will read close to zero Ohms.
You can use Siemens Drive test card. This card show you which phase IGBT is faulty. Even this will show you control main control board behavior.
This card will be placed in Place of CU2 or CUVC.
Hello all, I have a Controllogix 1756-L61 with some RIO. There are a couple of 1734-OB4E's that have gone bad. (no output voltage) My boss found...
1,106
Hello I am new here and new to PLC's, I wrote this program for a class that I am taking and my local tech school. The description is switch 7 will...
430
2,028
I'm trying to save a project as an L5X and I need to uncheck the "Encode Source Protected Content" checkbox, but it's grayed out. How do I get...
963
Hello. I have been working on my first plc project for a while now. I just ordered all the parts that I need and before I did that, I created the...
2,067
