plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 30th, 2014, 08:09 PM   #1
SourceGin
United States
SourceGin is offline
Fancy Exclamation VB2012 RsiOPCAuto.OPCServer
I've Started a VB2012 Project Looking at a OPC Topic in Rslinx Just wanting my tag value to show up in TextBox1.Text Any Idea's why it isn't or anyone have a better Code base to accomplish this /
'//Using RSiOPCAuto.dll
Imports RsiOPCAuto
Imports OPCAutomation
Imports Microsoft.Office
Public Class Form1
Dim MyOPC1 As RsiOPCAuto.OPCServer
Dim WithEvents OPCServer1 As RsiOPCAuto.OPCServer
Dim WithEvents OPCGroup1 As RsiOPCAuto.OPCGroup
Dim MyOPCItems() As RsiOPCAuto.OPCItems
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
'Dim OPCitems1 As ArrayList
MyOPC1 = New RsiOPCAuto.OPCServer
'OPCServer1 = New RsiOPCAuto.OPCServer
'OPCServer1.Connect("RSLinx OPC Server")
'OPCServer1.Connect("RSLinxEnterprise.OPCServer")
MyOPC1.Connect("RSLinx OPC Server")
OPCGroup1 = MyOPC1.OPCGroups.Add("REPORTING")
'ReDim OPCitems(1)
MyOPCItems(1) = OPCGroup1.OPCItems.GetOPCItem("[REPORTING]COUNTDATA2.ACC")
TextBox1.Text = MyOPCItems(1)
Old October 1st, 2014, 10:01 AM   #2
danatomega
United States
danatomega is offline
You have a lot of things commented out in your code that you may need.
This site has a VB.Net 2008 version for reference:
http://industrial-software.blogspot....th-visual.html
Old October 1st, 2014, 12:58 PM   #3
SourceGin
United States
Actually i don't those were just tests , i have it Working now thanks for your reply
Old October 1st, 2014, 01:36 PM   #4
danatomega
United States
Can you share what you did to solve the issue?
Old October 1st, 2014, 02:41 PM   #5
SourceGin
United States
Talking VB2012 RsiOPCAuto.OPCServer
i have an Complete Completed Project for Logix 500 and XP i was trying to Re-Develop For Logix 5000 on VB.NET 2012
After 24 Hours Of Coding i have it solved for Logix 5000
Anyone need assistance on Development Please Don't hesitate to Contact me ("VB6 / Delphi / VB.NET / ASP.NET / C# / PHP / ASP / PYTHON / PERL / BATCHFILE / POWERSHELL ") in Automation
Currently working on a Python OPC Server and Client
'//----------------MY SNIPPIT--------------------------------
'Tagvalue1Txt.Text = DATAVALUE1.ACC
'This is run when when the called from the btnConnect_Click
'Define OPCTopic to create the proper format for the OPCTopic to look like [OPCTopic]
Dim OPCTopic As String
OPCTopic = ("[" & TopicTxt.Text & "]")
'Create a new instance of OPC Server and call it OPCServer1
OPCServer1 = New OPCServer
'Now connect to the OPC Server we just created
'Create a new OPC Group in the previous defined OPC Server
OPCGroup1 = OPCServer1.OPCGroups.Add("REPORTING")
'Set the Group to the Active State for Updates and Events
OPCGroup1.IsActive = True
'Set the Update Rate of the OPCServer 1000 = 1 Second, which is the Default
OPCGroup1.UpdateRate = 500
'Instruct OPC Server to send OPC Group data Changes
OPCGroup1.IsSubscribed = True
'Add an Item / Address Point to the OPCGroup we just created
'"[RSLinx_Topic_Name]PhysicalAddress or Symbol if Symbols have been imported to RSLinx
'the ", 1" is the Client Handle RSLinx will get this first, the next one will be ", 2"
OPCGroup1.OPCItems.AddItem(OPCTopic & Tagvalue1Txt.Text, 0)
' OPCGroup1.OPCItems.AddItem(OPCTopic & "S:4", 2)
OPCServerConnected = True
End Sub
Old October 1st, 2014, 03:23 PM   #6
danatomega
United States
Thanks for sharing!
Old July 18th, 2016, 06:51 AM   #7
venkatgude90
India
venkatgude90 is offline
Unable to connect RSLINX Classic OPC using C#.NET
Hi
I am trying to create a test connection to RSLINX classic using C# code but I am getting exception when trying to connect.
Exception :{"E_NETWORK_ERROR\r\nCould not connect to server."}
InnerException: {"CoCreateInstanceEx: Class is not licensed for use\r\n"}
Please find attached screen for code related onformation and help me to sort out this issue.
Thanks,
Venkatesh Gude.
Old July 18th, 2016, 08:17 AM   #8
Archie
United States
Archie is offline
My first guess is that you only have RSLinx Lite which is not licensed for OPC use.
__________________
Expectations lead to disappointment. Appreciation leads to satisfaction.
AdvancedHMI - HMI Software without the license key hassles
Old July 18th, 2016, 08:44 AM   #9
venkatgude90
India
Hi Archie,
I just have RSLinx Classic installed on my machine.
Does it mandatory to have RSLINX Oem or Pro versions to connect from .NET applications?
I also observed an exception related to referenced dll(Interop.RsiopcAuto.dll) when executing below line
RsiOpcAuto opcsrvr=new RsiOPCAuto.OPCServer();
Exception details :
Retrieving the COM class factory for component with CLSID {DFB8323C-A952-11D2-A46B-00C04F796375} failed due to the following error: 80040154.
please suggest ways to get rid of this problem.
Thanks,
Old July 18th, 2016, 08:53 AM   #10
Archie
United States
Archie is offline
Yes. RSLinx Lite (the version that comes with RSLogix) will not work
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
