plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old October 21st, 2014, 09:51 AM   #1
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
[TOOL] What version is this MER/APA anyway?
Some of you may have noticed that I made a tool to determine what version a APA/MER was create in (V4, 5, 6, etc.). I originally hijacked robbo's thread as I worked worked this out, I thought it would be appropriate to make my own instead of continuing to post in his. Here is the original thread for reference
How it works: YOU MUST HAVE 7zip INSTALLED ON YOUR MACHINE FOR IT TO WORK. Basically I created a directory in your Documents folder called mer_ver. If everything goes as planned you will not see this directory for very long since I delete it when I'm done with it. Your MER/APA gets unzipped into this directory and I take a peak at a couple of files in order to determine the target version, original machines architecture (32bit/64bit) and whether the file was for ME or SE.
If you drag/drop a ACD file or an AutoCAD DWG, it will report what versions those were created in as well. This is something I did a few years ago so I tossed that in there as well.
I won't guarantee that it will work perfectly for everyone but it has worked fine for me and the limited testers I've had. The 32/64 bit thing was pretty unreliable, I made some changes for v1.3 and I think it should be pretty reliable now, at least with the files that I tested with. I think when it does report 32/64 bit it will be accurate (although you guys could convince me otherwise), it's just that sometimes it reports unknown.
Download
Old February 23rd, 2015, 01:47 PM   #2
jparale
Canada
jparale is offline
thank you dmroeder
Old January 11th, 2016, 10:13 AM   #3
thebuj
Canada
thebuj is offline
thebuj's Avatar
thanks! it worked for what I needed it to do.
I was able to determine the version a MER was from since I couldnt import from MER.
Old January 11th, 2016, 07:00 PM   #4
Patient
New Zealand
Patient is offline
This is great; just yesterday I was trying to check a version of a .MER file and found it quite frustrating.
Old January 12th, 2016, 07:12 AM   #5
TimWilborne
United States
TimWilborne is offline
TimWilborne's Avatar
Very nice. Great job!
Old January 19th, 2016, 11:13 PM   #6
stevensonjeff
United States
stevensonjeff is offline
Very cool tool! Thanks a ton.
Old February 3rd, 2016, 02:06 PM   #7
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
A bump because this tool just helped us walk into a dormant project and get a jump-start on the correct RA toolset for compatibility with the installed equipment.
Old February 3rd, 2016, 02:18 PM   #8
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
Glad it helped everybody. I use it occasionally for not just MER/APA's but ACD's as well. If you're ever curious, you can open the ACD as a text file and see all the times that it was saved and what version it was, so you can see the whole version history of a file. Of course after that information becomes gibberish.
Old October 17th, 2016, 03:39 PM   #9
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
Doesn't seem to work with FTView 8.2. I have version 1.3. Is there a newer one?
__________________
John
Old October 17th, 2016, 04:01 PM   #10
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
Heh, probably not. If you can send me a sample mer I'll update it when I get back from vacation. I still use 8.0. a 8.1 sample might be helpful too, assuming that is a thing
Old October 17th, 2016, 04:05 PM   #11
Dravik
United States
Dravik is offline
Not sure if there is a newer one, but the Hex for 8.2 is 03 08 14
Old October 17th, 2016, 04:07 PM   #12
Dravik
United States
Dravik is offline
and 8.1 is 03 08 0A
Old October 17th, 2016, 04:19 PM   #13
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
Quote:
Not the .mer file but the .apa file from FTV SE Station. Yes we're at 8.2 currently. 8.1 exists too.
__________________
John
Old October 19th, 2016, 10:44 PM   #14
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
I posted an updated version. I didn't get a chance to try it so maybe I could convince one of you to give it a shot? Thanks Dravik and John!
Old October 20th, 2016, 08:18 AM   #15
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
No go. Still shows unknown version.
__________________
John
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RSLogix 5000 skipping version 19 OkiePC LIVE PLC Questions And Answers 3 February 21st, 2013 07:19 AM
version backups plc noob LIVE PLC Questions And Answers 5 March 12th, 2009 11:08 AM
convert a simatic project from version v5.4 to version v5.3 Kataeb LIVE PLC Questions And Answers 4 March 6th, 2009 08:41 AM
Version Problem for Rockwell E3 module Eric Le Yin LIVE PLC Questions And Answers 4 January 22nd, 2009 02:05 AM
Downgrade Intouch Project Version alpha98 LIVE PLC Questions And Answers 16 March 21st, 2006 10:46 AM
