plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 24th, 2014, 02:32 PM   #1
CobMoo
United States
CobMoo is offline
PanelView Automatically Enable Barcode Reader
Hey all,
I have a PanelView Plus 1000 and have a barcode reader hooked up to it. Currently, I can use the barcode reader by opening up a string input enable box and scanning the barcode. This inputs the barcode and closes the display. This all works fine.
What I would like now is to not have to press the input box each time I want to use the barcode. Is there a way to have the barcode reader automatically use that input box? Or if that is not possible, is there a way to open up the input keyboard display automatically when the screen opens. That way as soon as I open the screen, the user can scan a barcode.
Any help would be greatly appreciated.
Old November 24th, 2014, 02:48 PM   #2
widelto
Colombia
widelto is offline
widelto's Avatar
Is that a manual barcode reader?? There are some manual barcode readers that has a read button, this button is recognized by the PLC. The you can use it to do whatever you want.
__________________
My two cents.
Old November 24th, 2014, 02:57 PM   #3
arlenjacobs
Canada
arlenjacobs is offline
If you had a serial port barcode scanner, you could use Kepware and the UCON driver.
That solution would automatically scan the barcode directly into a string tag for you.
But it sounds like you have a USB barcode scanner, which is basically a USB keyboard. There is no built in support with PanelView to do what you are asking.
Old March 2nd, 2018, 12:01 AM   #4
gwk_king
United States
gwk_king is offline
Hello,
I am working on a similar system with a USB Barcode Scanner that is hooked directly to a Panelview 7 Plus Standard. Was there any other configuration involved aside from using a string input enable box to populate the data in? I am trying to avoid using the Kepware and Ucon Driver. I just need to select the string input box and scan the barcode in it.
Thanks,
Old March 3rd, 2018, 12:22 AM   #5
JaxGTO
United States
JaxGTO is offline
If you can make your barcode reader kick out an F key you can assign that F key to the entry box
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Connect PLC to Barcode reader hoejinkim LIVE PLC Questions And Answers 1 May 10th, 2013 01:24 AM
Rfid / barcode reader yasirkhi LIVE PLC Questions And Answers 3 December 12th, 2012 09:09 AM
Micrologix 1100 and Ethernet/IP barcode reader SCUBA NooB LIVE PLC Questions And Answers 2 June 11th, 2011 10:20 PM
the Plc program for new barcode reader ghost-ronald LIVE PLC Questions And Answers 0 September 9th, 2007 02:51 AM
Barcode Reader halburgepramod LIVE PLC Questions And Answers 0 April 11th, 2007 11:54 PM
