justin lutz
Hello all.
I was told that you could run a "desktop" simulation between these devices to test out your programming, but I am running into issues on the OIT side.
When I start the PLC simulator, all is well and I can step through the program.
When I start the OIT simulator, I receive the following error: "PLC returned error code. (FDH - C1C0H) (ModbusEquipment03)" where ModbusEquipment03 refers to my PLC. I am using 127.0.0.1 for the equipment IP address. The PLC is also configured with this IP address and is in Simulator Mode.
Does anyone see any glaring errors as to why I cannot get the "full" simulation to work?
Thanks,
Justin
Thanks,
Justin
