Hello all,
I am very new to plc programming and have been watching videos, and reading up on them. I have a beginners class Mid March.
I have a Micrologix 1500 controller that I am using RSlogix 500 to tinker with on my desk. I can connect to the PLC go online and manipulate the program.
This will be a real world project.
Controlling sump pumps in our sump drain.
The normally open float switch will determine how long the pump runs, water rises in the pit the float switch closes and the pump comes on, water level falls the switch opens and pump shuts off.
I want to be able to turn on another output to a solenoid valve when the float switch closes to turn the pump on for a specified amount of time. then shut off even though the float switch is still closed running the pump.
Water rises>float switch closes> this is connected to an input on plc > this starts a timer as well that runs for 1 min > turns on an output> timer times out> turns off that output> pit is not drained so pump is still running till water falls in pit to open float switch and shut off pump> starts all over again when water rises.
I am currently doing this with a mechanical timer, I figured this would be a good real world project to learn on and not interfere with production machines.
I already have a TOF timer controlling an output in the small program I have written so far, this works as I need it to, it will do something else associated with the sump pump process.
We have self priming sump pumps and they sometimes lose their prime. The output will control a solenoid that comes on when the pump starts to open the water valve to prime the pump each time the cycle starts.
The TOF timer will run after the pump shuts off to wash a screen that we screen the sump water with.
We make color concentrate and screen and filter our sump discharge before pumping into the sanitary sewer.
I searched the forum and see some sump pump projects. If this is in there I did not see it.
Thanks for making it this far.
Scott
Scott
