A little off topic but i cant find any infromation
e27978
Sep 2006
washington pa
35
I have an existing low voltage cable tray 24volt power and signala and I need to mount a cellular antenna for communication with a plc is there any issue with mounting this small antenna to the side of the cable tray it's the most convenient location
You have my permission.
Dang Russ, if I knew that you were so easy... :)
To the OP: Go for it, it won't cause a problem (with the signal at least. The first time that someone has to get into the tray and knocks your antenna loose is a different issue entirely).
the electricians will rub your antenna on their next cable pull, or drape some cables across it while they pull in... just speaking as an electrician :) just make sure it is strongly attached and that the antenna lead is protected
Hi, I need to compress 3000 ft^3 of a syngas(synthetic gas) made up mostly of hydrogen, carbon dioxide and a little methane. I cannot seem to...
2,531
A registry setting was changed on my windows xp home laptop. This setting, greyed out my windows update settings (auto download, etc.) Has...
1,993
Hello everyone I know this is a little off topic but was wondering if anyone has come across a device to remotely control 3-5 (120 VAC)...
5,210
I’m currently a student of Communication systems, majoring Multimedia and Design in The Netherlands. My first education was Technical Production...
2,648
This was posted on the AD forum and I just had to bring it over here for all the Rockwell people to enjoy. http://media.ebaumsworld.com/retro.wmv...
3,995
