1 sec pulse bit running up my ADD instruction to fast
Snap25
Dec 2014
Michigan
237
Objective :
Once the inlet flow drops below the set point on the filter chamber it starts a cleaning sequences and flushes the filter with pulses air and water to break up the solids that are building up on the sleeves.
Logic to control how many pulses to run to flush each sleeve :
I'm using a 1 second pulsing bit created from the status files to add up my pulses with an ADD and LEQ instructions.
Every time it pulses it is supposed to add 1 to the ADD destination but during that "1" second when it pulses, it adds up more like 8! The rest of the logic works correctly but I'm just not getting the pre set amount of pulses to clean each sleeve because its accumulating more than 1 in that one second pulse!!
Am I going about this the wrong way?
Ok what triggers your sec pulse?
Not sure if the ML1100 supports theses but maybe look at the S:4/6 bit or use the STI if you need a precise sec pulse
You need to use a one shot after the status bit before the add
this will allow only one pulse to the add per 2 second if you have
used the status bit that changes state ( 0 or 1 ) at that rate
Without the ons or osr
what you are probably seeing add up is the scan rate
or it maybe the bit you selected is the one eighth of a second
move it up three more bits
I'm using the one second bit from the status file. I thought the one second timer seemed pretty accurate but I guess not because during that 1 second it makes the run true, it adds around 8 instead of 1 to my add instruction.
Objective :
It sounds like your 1 second pulse is staying true for more than one scan of the processor. Use something like an OSR to make sure that it is only on for one scan.
However, if you are only trying to count seconds, you could start a timer and use your compare statement with the .ACC of the timer. You won't actually use the timer, just use the Accumulated value to count seconds.
This is off the top of my head, I don't work with A-B processors as much as I used to.
I'm going try putting an OSR bit first and go from there. That should do it.. I don't know why I didn't think of that!
Depending on how low the cleaning cycle last you could use a counter instruction instead of an add instruction. A counter only increments on a false to true transition. The add instruction adds each scan while rung is true.
Use the pulse bit to trip a counter, not an add instruction. The counter only increments up on a change of status, not every scan.
Objective :
You need to add ONS instructions before your ADD instructions. What's happening is the Status file Pulse bit stays on for more than one scan, so whenever the pulse bit is on, it will add 1 to your total every time that piece of logic scans. Certain instructions, like CTU and CTD have this built in and only execute on false-to-true transitions, but that is not the case with arithmetic instructions. Either use a CTU instruction instead or add a ONS.
I am Using omron cx-programmer. In this programme the 1-sec clock pulse bit timmer is avalable in programme itself.I want to add new 5sec clock...
6,043
HI ,, I Want to create 1 sec pulse in rslogix 5000. can anyone tell how to create this. so that i can calculate machine runtime. thanks,
18
8,705
Good afternoon to all. I am new here and seeking your vast knowledge. I have been tasked with pulsing the alarm light in multiple machines with...
5,336
Hey, i wanna use SM1032 on a Mitsubishi Q-CPU but it doesnt switch on/off when i use it, do i need to eneble that function first? Thanks,
11,040
how do I create a 1/10thsec clock pulse, if any one could tell me that would be great. Im using Syswin
2,365
