plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 29th, 2015, 12:29 PM   #1
Rob S.
United States
Rob S. is offline
Dog Replacing Freq Drive brand on ModBus
Good Afternoon ,
We are doing a small upgrade on a certain portion of a machine but I would like to keep the Modbus network. I would like to replace 2 Schneider ATV312H075N4 Drives with AC Tech Drives. We are communicating with Modbus . How difficult is it to replace a drive with a different brand on a Modbus network.
It cannot be has easy as making the Modbus address the same on the AC Tech drive as is on the Schneider ATV312H075N4, is it ? I'm sorry , I am just not too familiar with Modbus like I should.
Thanks in advance,
Old April 29th, 2015, 12:57 PM   #2
jraef
United States
jraef is offline
jraef's Avatar
No, it's not that easy, but it's not too difficult either if you have any communication string programming capabilities.
First obtain a "Modbus Register Map" for both drives. Then look at your PLC program for where it accesses the drive via a comm command, and look at the Modbus communication packet that each command is currently utilizing for the ATV drive. Each command will be in the form of a packet of data conforming to the Modbus standard format, and buried in that packet will be the register address within the device (not the NETWORK address) and the bit value(s) that gives the drive the command(s) it needs. Using the map, determine what that register and bit value corresponds to in the drive programming, then find the matching register and functions in the AC Tech drive. Replace the ATV register number and necessary bit values with the AC Tech register and bit values number in each command in your PLC code.
You may also need to double check the packet format to make sure they match. Modbus command packet formats are SUPPOSED to all look the same, but sometimes they are tweaked by manufacturers, and that only ends up being an issue when you try to do something like this.
If all of this looks Greek to you, consider farming this out to a pro.
Old May 8th, 2015, 08:25 AM   #3
Rob S.
United States
Rob S. is offline
If I replace the Schneider ATV312H075N4 Drives was the Altivar 31 Drive , with Modbus , if I set it up with the same address and other parameters it should run the same , correct ?
Old May 8th, 2015, 08:33 AM   #4
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
You will actually have to read manuals and compare the the Modbus locations of information in the two drives. It is very unlikely that they will have precisely the same information in the same location.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old May 8th, 2015, 09:01 AM   #5
nonuke
Portugal
nonuke is offline
nonuke's Avatar
Quote:
If you don't want to read the manuals, you can ask Schneider Electric for help.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Abb Ac Drive rajendrad LIVE PLC Questions And Answers 13 November 5th, 2006 10:18 AM
Heller milling machine controls and drive naveen LIVE PLC Questions And Answers 8 August 22nd, 2006 08:40 AM
Drive freq. Alan Case LIVE PLC Questions And Answers 9 May 28th, 2003 12:59 PM
AB Drive Tools(V2.06) W/SC 300 Interface Vietnam Bob LIVE PLC Questions And Answers 0 November 20th, 2002 09:19 PM
Off topic - personal rant!! PLucas LIVE PLC Questions And Answers 11 September 9th, 2002 08:25 PM
