Micrologix 1400 to Powerflex 525 over ethernet
pauljm
May 2015
Australia
Hi all,
Great forum first time at posting. Have been searching but can't find any info on the above subject. I have set IP adrresses in PF525 and ML1400 and can communicate to them but the 525 does not seem to register my start commands. I can open the Control Bar in CCW and start the 525 from there and then i am able to start and stop the 525 thru the ML but i cant control it purely from the PLC. Can anyone tell me if i need to set any of the Datalinks parameters in the 525? Parameters C153 to C160 are the ones i think i need to modify but am unsure what to set them at? The Ethernet light on the 525 is flashing which means its is connected to the network but not being controlled through ethernet. Sorry for the confusing description but i have been going round in circles on this for the last 12 hours and it is doing my head in! Any help really appreciated....
Cheers...Paul
C129-C136 should be set to your IP address and subnet mask.
Also, P046 (start reference) should be set to 5 for ethernet. P047 should be set to 15 for ethernet also. Here's a list of parameters we set when we use 525's over ethernet.
P031, P032, P033, P034, P035, P036, P037, P039, P041, P042, P043, P044, P046, P047
C128-C136
T105
Check out http://literature.rockwellautomation.com/idc/groups/literature/documents/um/520-um001_-en-e.pdf on page 61/62
EDIT: As for C153-160, I've never messed with them.
PowerFlex 525 - can you access the parameters from a MicroLogix 1400 & CompactLogix Good Morning , I have a separate stand alone machine...
3,317
Hello my name is cristian, I have little experience in programming. I want to make a variable speed motor with a powerflex 40 and mocrologix 1400...
4,100
Hello, I am pretty new to the PLC world and have a Micrologix 1400 PLC commanding several small Powerflex 4M VFDs on a bottle capping machine via...
3,883
Dear All, kindly help me for Power flex Drive 4M (1.5Kw 22Fcation of -D4P2N103) communication with Micrologix 1400 by RS485. Actually,I am new...
3,520
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
180
