plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 28th, 2004, 12:17 PM   #1
royle johnson
United States
royle johnson is offline
mitsubishi plc programming software
I am looking to purchase Melsec plc programming software.It is the older version not the newer GX developer.It is listed as Melsec Gppwin
-E,or just Melsec GPPW.Does anyone know where I could find this? I
understand that this software can program the FX and A series plc's.
Thanks.Royle.
Old July 28th, 2004, 02:53 PM   #2
panic mode
Canada
panic mode is offline
panic mode's Avatar
Gppwin is predecesor of GX developer. In fact GX developer
is newer version of gppwin. The older software that is DOS based
is called Medoc and it should be free for download.
I never used Medoc so I wouldn't expect it to support newer CPUs.
If you plan on working only with FX and A series, even Medoc
should be ok. Some people like it (I don't like any Japanese
software or manuals but that's just me...).
Old July 28th, 2004, 07:32 PM   #3
tommy23t
United States
tommy23t is offline
tommy23t's Avatar
I was also told that the newer plcs wouldn't work with dos Medoc.- wrong- On a whim, I tried it on a FX1S, and was able to download and upload to it.
tommy23t
Old July 29th, 2004, 09:02 AM   #4
Goody
United Kingdom
Goody is offline
Goody's Avatar
Medoc can see the newer FX's and A series but it sees them wrong. (same for some newer models in gppwin)
So it will report the available bits (counters, timers, internal relays, etc) and memory wrong too.
I am not sure wether you can use these bits that you know are there but medoc says they arnt or not because I always upgraded my software to suit the plc.
But I remember medoc and gppwin seeing an fx2n as an fxon and saying there was 2k memory when the book said 8k
Old August 2nd, 2004, 05:38 PM   #5
royle johnson
United States
melsec gpp win software
Thanks for the response. I am still wondering if this gpp win software can be purchased. The newer version Gx Developer is quite
expensive.Mitsubishi does not offer the older gpp win for sale for
obvious reasons. Royle.
Old August 3rd, 2004, 09:59 AM   #6
abuelfun
Sudan
abuelfun is offline
mitsubishi programming software
Fore melsec plc programming software you can go to (www.plcman.co.uk)and download from this site.
Best regards
Old November 17th, 2005, 11:36 AM   #7
ctsautomation
United Kingdom
ctsautomation is offline
I can email it if you want, follow my link at www.******************
regards
Old November 18th, 2005, 03:12 PM   #8
NorthControl
Norway
NorthControl is offline
NorthControl's Avatar
Version
Hi!
Medoc can handle any Mitsu PLC except the Q-series as far as i know.
The only thing is that it has "Lately" came out newer versions of medoc for the newer fx1 and fx2 series. However, you can program a fx1 plc with "fx0 medoc version" but you would not get full control of all the functions and memory areas etc.
I have medoc 2.40 that handles fx1 plc.
Old November 21st, 2005, 03:50 AM   #9
Dariusch
Denmark
Dariusch is offline
Dariusch's Avatar
The medoc can actually handle the Q-series. BUT it is only a special version of medoc, that was made by Beijer in sweden. I do not know if the software is relased for sale.
You should go by the GX og GX-IEC Developer.
Best regards
Dariusch
Old March 13th, 2006, 12:21 PM   #10
Sergei Troizky
Canada
Sergei Troizky is offline
I have succesfully used old Medoc versions with later PLC models.
For example, versions 2.3 and earlier did not support FX1S and FX1N, but could work with them when defined as FX0S and FX2N correspondingly.
Just curious whether Medoc will work with FX3U. Anybody tried?
Old March 13th, 2006, 12:26 PM   #11
BTalbot
United States
BTalbot is offline
BTalbot's Avatar
Quote:
tommy23t
Medoc will work with FX1s, FX1n, and FX2n, as long as your not trying to use any instructions that are new (such as in-line compare, and invert, etc.) I do't think it will work with FX3U but that's only a guess.
Old March 13th, 2006, 04:56 PM   #12
rohan tandon
United Arab Emirates
rohan tandon is offline
You can think about using the free GX developer ver 8... the only catch is that there is a 1000 step limit. Is it good enough for u?
the link to the download is: http://forums.mrplc.com/index.php?download=526
Old March 14th, 2006, 11:24 AM   #13
504bloke
England
504bloke is offline
504bloke's Avatar
Out of interest does 1000 step mean 1000 rungs of ladder ?
Or does step mean each piece of logic on each rung ?
__________________
Regards
Dave
"When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity."
Albert Einstein (1879-1955)
Old March 14th, 2006, 12:30 PM   #14
Goody
United Kingdom
Goody is offline
Goody's Avatar
No!
Each bit is 1 step ie 1 n/o = 1 step
But, instructions can take several steps - the longer the instruction the more steps
ie -[MOV K4 D0] (move the decimal value 4 into data register 0 takes 5 steps
Old November 1st, 2016, 08:36 AM   #15
gibbom
Australia
gibbom is offline
gibbom's Avatar
Hi Guys,
I am a complete NOOB when it comes to Mitsubishi PLCs, however would like a small amount of guidance for kicking off.
I'm wanting to connect to a fully installed Q4AR CPU (from what i read its a powerful and redundant PLC). I want to be able to go online and upload the program from it so as i can determine what the I/O is meant to be doing. Could someone please help me for the following questions:
1. How do i physically connect to the unit (Comms cable type, comms method, comms settings)
2. What software will I need to download / buy in order to upload the PLC program from the PLC.
3. Will the same setup for qu 1 and 2 allow me to connect to a Q2AS CPU PLC?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
mitsubishi PLC software ??? plcproblem LIVE PLC Questions And Answers 8 November 17th, 2005 11:37 AM
Generic PLC programming software divertas LIVE PLC Questions And Answers 6 January 26th, 2005 02:35 AM
Mitsubishi FX PLC Tim Ledwith LIVE PLC Questions And Answers 16 December 15th, 2004 12:07 PM
DirectLogic 405 PLC Programming wilvil2000 LIVE PLC Questions And Answers 1 December 5th, 2003 10:37 PM
Melsec programming for mitsubishi plc h_wings LIVE PLC Questions And Answers 3 September 19th, 2003 02:07 PM
