plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 18th, 2015, 11:19 AM   #1
Pete_S
United States
Pete_S is offline
Unhappy Siemens S7-300 MPI to OPC server connection
Hello All,
I am having trouble setting up a S7-300 MPI connection using Simatic Manager 5.5. I am trying to use an OPC server with a S7 MPI driver to read data from the PLC. I have an S7-300 that has a valid MPI connection configuration but that controller does not have any data blocks configured. After too much time beating my head against my desk I decided to reach out for help. Can someone help me with steps required to pull running configuration on MPI configured PLC into Simatic manager so I can add a add a data block or configure from the ground up? I have experience with AB, GE and DirectSoft products but Siemens is really giving me a run for my money. Thanks!
Old September 18th, 2015, 02:57 PM   #2
Thomas_v2
Germany
Thomas_v2 is offline
you can first try to read marker/flag values. They are always there, even without any program in the plc.
The basic setup for accessing a S7 via MPI is the MPI address of the CPU and the rack/slot combination. This is the position of the CPU in the S7 rack. A S7-300 has always a rack/slot combination of 0/2. With a S7-400 there are other combinations possible, as you can place the CPU on a position you want, or you can have multiple CPUs is one rack.
Who is the vendor of your OPC server? The item namings differ always a little bit between them.
Old September 18th, 2015, 03:25 PM   #3
Pete_S
United States
Pete_S is offline
Quote:
Originally Posted by Thomas_v2 View Post
Hi Thomas_v2,
Thanks for your swift reply. I am trying to resolve an issue with Proficy OPC server running on a Quickpanel+ where floats in a data block can not be read. I have successfully created a project from scratch for my CPU315-2 PN/DP controller that has a data block with a few floats in it. I can successfully connect to controller using Kepware S7-300 Ethernet driver and read/write to floats in my data block. However when I connect null modem serial cable to MPI adapter and Quickpanel+ I am not able to get good quality on any known tags such my DB floats or other generic registers as you referenced.
I am confident that I am missing something in my object configuration in Step 7 as I have an older CPU315-2 DP controller that the MPI was originally connected to with a program running and I am able to connect the Proficy server running on the panel and connect to known registers, but no data blocks are on that controller and I don't have backup for that controller.
So I see 2 ways to resolve, and I am stuck on both:
1: find the MPI configuration "gotcha" in my CPU315-2 PN/DP config so I can connect to the server on the panel
2: find a way to preform blind upload from CPU315-2 DP controller. When i set PN/PG interface to either PC (auto) or PC (MPI) and attempt to upload I get an error that the connection link can not be configured or is broken respectively. That controller does not have an Ethernet port, and although I have a Simatic NET 343 module in the rack it appears that it is not possible to upload from that module.
Any advice would be greatly appreciated!
Old September 18th, 2015, 03:39 PM   #4
Thomas_v2
Germany
Maybe someone has changed the MPI baudrate, for any reason.
The default baudrate is 187.5 kbit/s. I would try all available baudrates, and use the "show reachable partners" dialog from the Step 7 manager, as it should show you the CPU even if it has a different MPI address as configured.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens s7 312c connection to PC Finn Gevind LIVE PLC Questions And Answers 4 October 31st, 2012 02:49 AM
Using Siemens OPC Server 2006 (V6.4) with Step7 V5.3 ghobnik LIVE PLC Questions And Answers 5 May 23rd, 2008 10:03 AM
OPC for Siemens S7 300 via cp5611 noomj LIVE PLC Questions And Answers 6 December 21st, 2007 01:34 AM
OPC Server for Siemens and Ethernet Prince LIVE PLC Questions And Answers 8 August 24th, 2004 06:52 AM
Siemens S5 135U Peripheral I/O Addressing in OPC Server shady_yehia LIVE PLC Questions And Answers 5 July 14th, 2004 08:02 PM
