Beckhoff ADS communication
M4rk06
Sep 2015
Laval
Hi, I need to make two twincat 3 PLCs communicating together. I read about the Beckhoff ADS communication protocol but could not find that much information. It looks pretty simple to set up though.
If anyone knows it well could you tell me if it is a reliable protocol like TCP/IP and is it fast? Also it will probably be over wifi. Would you rather use another protocol?
Thanks!
I want to read variables from the PLC with my C# programm. Is it possible to run my c# programm on a computer without the TwinCat System...
2,805
TwinCat3 Beckhoff "Add route to remote system failed ADS Error 1804 (0x70C)" Hi everyone, I have a problem connecting with a Beckhoff CX5120...
40,346
Hello all, I ran in to some trouble. I created 2 virtual machines to try out ADS communicating One machine is a PLC (TC2 32bit (runtime)), other...
19,972
Hello all: I am in the process of writing some drivers on a PC that will communicate with a Beckhoff PLC via AMS/ADS :banghead: . I can request a...
4,579
I has an industrial pc connect to the controller. And write the PLC program to control the machine On and off in the industrial PC. It is work...
24,179
