RS Logix 5000 Fatal Error Message when Opening Application
Rob S.
Sep 2008
Maryland
739
I searched for this problem on some threads , but they were dated in 2013 . When opening a program , and not all my programs , I get the following Fatal error below. I have V20.01.00 (CPR 9 SR 5) of RS Logix 5000. Have many of you had this problem , and what was the best fix ?
Thanks so much for your help.
Sat Oct 10 11:11:25 2015
Fatal Error!
Application Path: C:\Program Files (x86)\Rockwell Software\RSLogix 5000\ENU\v20\Bin\RS5000.Exe
Elapsed execution time: 7 seconds
Version: V20.01.00 (Release)
Source File: unknown
Line Number: -1
Function/Method: unknown
OS Version: Windows 7 64-bit (Service Pack 1 - Build 7601)
Thread Id: 000026f4 (9972)
Error 0xe06d7363 (-529697949)
RxEXCEPTION_MICROSOFT_C_PLUS_PLUS - A Microsoft C++ exception was generated but not handled.
One project file is currently open:
C:\USERS\BSMITH\DESKTOP\Spray_2014037081.ACD
Work Path: C:\Users\bsmith\AppData\Local\Temp\RSLogix5000.Temp\AB_6952\AB_6DF1
Time open: 0 seconds
This is a very generic error and there are many reasons why it would happen.
Since you can open some projects, my guess will be that this is related to one of Add-On profiles installed on your computer.
There are many technote in the Knowledgebase related to the same error, but I would start with "Repair" option under control panel as described in TN 471207. You may try CTRL+SHIFT reset as well.
Are these projects created on the same computer? did somebody with a later minor rev of V20 opened them before? You can actually open these ACD files in the notepad to see it.
Thanks. In control panel , where is the repair option ? I thought it would be under right click. They were uploaded by a co-worker and e-mailed to me. I installed Studio 5000 Version 21 and I still get that error.
Thanks again
You need to open file in notepad to see revision
I suspect he may have 20.03
V21 will not help you
Repair rs logix 5000 shold be available in control panel when you double click on rslogix line
If I highlight RSlogix 5000 v20, I can see above the list Change option.
Wizard will open and it allows repair
Much owed Success
Just started having this issue in the last two weeks. Rockwell said to update the PLC, but the man in charge agreed that that was a risky idea.
Followed your services/change/repair instructions and it worked immediately after reboot! (y)
Hi All, I've been pulling my hair out trying to fix this for a few days and need some advice. I have V19.01, v20.05, V21, V24, V30, V31, V32...
396
I've googled and searched for this error but can't see it anywhere. When I try to open this program I get the following. Error 0x8004201d...
3,950
Hello All, I have been getting this fatal error repeatedly when trying to connect to a PLC in our facility. I have never come across this...
1,816
Good morning, I am getting an error when opening my RS Logix Program. Picture attached. This happened with the recent windows update, so I...
1,494
Help! I have been using RSLogix 5000 on my laptop for over a year now (Version 20.01.00), and have recently installed RSLogix 500 on the same...
8,786
