1398-DDM-150 Drive/Ultramaster Help
jwhite3615
Sep 2015
Springfeild
I have a 1398-DDM-150 Drive that quit working on a press feeder at work, we replaced the drive and i'm trying to connect to it using ultramaster to install the parameters into the new drive but I keep getting "no drives found on node scan" i tried every possible baud rate, parity, and stop bit possibility, I am using a computer with XP on it currently with a working serial port and cable, I have tested the cable using the hyperterminal that came with windows, and also double checked it by using it to go online with a SLC 5/04 CPU, if anyone has any ideas on how to connect to these drives, please help me out, thank you in advance
edit: We have 3 of these drives still running on equipment in the plant, I am unsuccessful at connecting to any of them, so i assume it is something i am doing wrong
Justin
Trying to get communication over RS232 back on AB Ultra100 1395-DDM-005X-DX drive after playing with different settings drive fell in "Limbo" mode...
1,386
Hello! we have a broken PDM-30 driver and would like to migrate to newer technology, What would be the best option? Ultra 3000? Kinetics 6000...
1,598
I have a customer tha has several servo feeders for metal stamping. The biggest part of them are Reliance IQ and AB 1398.They have one or two...
1,935
Hello All, I have a small Blanchard that uses an Allen-Bradley 1398. When the machine is powered up, "Invalid Opcode" is displayed. I do...
5,971
Hi to anybody; I have here PDM-75 or ElectroCraft 2000 series module; (now is A/B 1398-PDM-75, and work in one of the machines with some...
5,483
