24 hour clock on a SLC 500 Fixed IO
JSPLC
Mar 2009
Santa Rosa, CA
I have a fixed IO SLC 500 that I need to program with a accurate 24 hour clock. The system does not have a date/time function so I used a free running TON to increment CTU's to provide minutes, hours and days. The accuracy is very poor and I was wondering if if anyone could suggest an alternate approach?
The thing about a TON is that it will usually over run the preset depending on the scan time of the other logic, this can be a significant error.
What I do for a long duration timer is to never reset the timer, instead, I subtract from the accumulator so that the overrun amount is still left there. I also always use the finest resolution timebase available.
Paul
Hey OkiePC,
I was using a very similar structure and I still had an accuracy issue. I actually varied the B source value of the GEQ to try and reach an accurate time over a few days but it still drifted. Part of me thinks that there could be a temerature stability issue that I am fighting (the unit is not in a controlled environment but not exposed to extreme temperature fluctuations).
Paul - I don't get the need for the 59 preset on the minute counter and 23 preset on the hour counter. The DN bit should go true when ACCUM >= PRESET.
Yep...my mistake...That was not from a real program, just an example for the OP...
As for the accuracy, even with the GEQ---SUB, the clock itself is not extremely accurate.
At my previous job, we found that the SLC clocks would be off by up to two or three seconds per day and the PLC5s were even worse.
You may have to perform some sort of re-sync periodically to do better than that. Is the SLC connected to a network?
Well, how about something like one of these:
http://www.ipfonline.com/store/products/2287.html?catid=2287
http://www.omega.com/ppt/pptsc.asp?ref=PTC900
http://www.bb-elec.com/product_multi_family.asp?multifamilyid=39
http://literature.rockwellautomation.com/idc/groups/literature/documents/pp/1760-pp001_-en-p.pdf
In combination with Mildrones idea in Bernies link above...
Have the real time clock relay pull in every day at a predetermined time and cause an input to the SLC to turn on. Then in the SLC use that input to reset your clock registers.
Paul
I have often thought that an external trigger would be an easy solution, and I just might go that route, though I was hopping to be able to solve it with just the PLC.
PS - I just want to thanks everyone for their input - this is a great site and a great community.
Hello I was needing to stop one device and start the second device at a certain time each day, for example 10:00 am each day. I thought the best...
5,267
In the GT designer 3 project the time looks correct, but when Iake the project "live" it's 1 hour behind. What's makes it more odd is that when...
2,783
Hi Able Engineers! How can I use Real Time Clock (RTC) to get flow per every hour and Day on RSL0gix500, Assuming I want to see volume of Liquid...
3,126
My Wall Clock , on a CompactLogix ,as been working great , until now. My Year , Month , Day , Minute , Second , and Microsecond is good , but my...
1,884
Create a 24hr clock , which will show on LED display, the LED will display hours and minutes Conditions: only one TON can be used. All other...
3,934
