Hey guys, I am looking at upgrading a machine from an old PCB controlled process with a membrane button control interface, to a PLC with a touchscreen.
Im in the stages of quoting and trying to figure out how I would tackle the logic to handle the 9 hopper sorting.
Currently, the machine works like this:
1. Potatoes roll down the main chute to a divider which rolls roughly 3 potatoes into each hopper.
2. Each hopper has a load cell on it and it displays the individual hopper weight on the LCD display
3. After all the hoppers have been filled, the machine pauses for a split second, then opens any combination of hoppers which equate to putting the combined weight just over the setpoint (i.e. - 10lbs if needing 10lb bags). It could be any random combination of hoppers.
4. The weight need to ALWAYS be equal or great to 10.00lbs and typically is only over by 20-50 grams. Of course depending on how the hoppers are stacked up.
5. I also need the ability to disable/enable hoppers if they are pulled for maintenance.
I have the load cell amplifier picked out, and have know how I will tackle the rest of the code on the machine. Its just the above I keep scratching my head on.
What would the process of logic look like for something like this?
No, there is no way to extract the code from the ROM chip on the big ol' PCB board.
To keep cost down, I am looking to use Automation Direct Cmore and BRX hardware. FYI.
