Ab 9300-ena nat
Larz
Sep 2020
North Carolin
I have an AB 9300-ENA. This is the 4th one i've configured. Never had a problem til this:
I have 3 plcs configured. The 9300 sees all 3 and the devices associated with each plc. i can only access one of the controllers. the other 2 i can't even ping. even though they show up in the devices (green) on the 9300.
Anyone ever run into this issue? if so, what was the issue?
Thanks in advance.
Hey Larz,
I have faced this problem in the past and changing the public port along with assigning a new public IP for the controller in the NAT table helps. I'm sure you have setup the NAT with the proper gateway, did the NAT lost power before this problem or was it a new configuration.
There has been no clear answer to why this happens from AB side and it is frustrating to deal with it where the NAT can ping it but the it's unresponsive from the public side, the mentioned problem also doesn't work in every scenario. [even after replacing the 9300-ENA with a new one]. Additional question which switch are you using for your setup
If you found a solution please share the same , the mentioned solution has worked for me twice though the second time I struggled for 5 hours before I could get the line back up
1st scenario - standalone machine with 6 axis servo system, main goal is to isolate servo drive data from entering the plant network. We will...
5,531
I am having some communications trouble with the Allen Bradley 9300-ENA. Here is a rundown of our system: On a piece of equipment, we have a...
4,037
Hi all. I have been an IT worker for many years. Most of it in server support and networking. However I am VERY new to the PLC environment, but...
2,132
Good Afternoon , This is one of my dumbest questions yet. I never set up a NAT translator before. When you use a web browser , I can use...
7,677
Hi, I'm about to buy a NAT device, and I found this 2 versions on the Rockwell site, but only specific information about the 1783-NATR for the...
5,860
