AB1500 Need to monitor the instantaneous Power coming from a 150 HP
piscis
May 2003
241
I’m working on two “Energy Consumption” projects for two different customers with two different PLC; AB1500 and AD260, the two most popular PLC in our island. My question below refers only to the AB1500 PLC.
We installed a true power sensor (model #UPC from Load Controls) this sensor has only a 4-20ma output to the PLC.
I need to monitor the instantaneous Power coming from a 150 HP Air Compressors, which is turned ON in the morning and turned OFF 12 hours later, loading and unloading all day long.
I need to show on a Touchscreen the amount of money this compressor has cost the company for the period it was ON
I would like to receive from you some ideas on how to make the power used by this compressor as real and as close as possible to the actual KW consumption on a 12 hours period.
Would you grab a reading every 3 seconds and average it over an hour? How would you do it?
Does AB have special instructions for this type of applications?
Thanks for your answers.
Multiply the KW with time to get KW hours.
Totalize the KW hours.
Then multiply the Kw hours by the rate.
Also look into kVar Charges and any Max. demand charges.
Alot of money can be saved on demand charges, depending on how the utility calculates the monthly bill.
Hello All, I'm new here so pls bear with me. :) I have an AB1500 PLC and I am trying to use the PWM or PTO function to control the speed of a...
3,296
Does anyone knows if the PLC AB1500 has a nice instruction like the AutomationDirect Ibox “INC” instruction, (increment) where you can use it as a...
2,071
Does anyone know if AB1500 PLC has an instruction like this one in AD “Filter Over Time - BCD (FILTER) IB-422” Or may know how to accomplish the...
2,421
I need to start working on an HMI project using AB1500 with Citect. I would need at least 3 drivers to connect to PLC using DF1, Vision System...
1,570
Using a single instruction I can add up these 60 single-word registers on AD. On AB1500 I need to use 60 instructions. Does anyone know if AB1500...
3,608
